dodge caravan door lock relays
ctc345
Member - Posts: 11
Posted: January 07, 2006 at 11:10 AM / IP Logged
hey ppl. im trying to find out which terminal (s) do i wire into for power door locks for remote starters.ive multi plexed them before and i find it a pain in the butt.i was told i could go right to the relay but im not sure which terminal.... can you help please. im installing pro starts if it matters,the unit gives a negative pulse.
Rob C. CANADIAN TIRE (345). WINNIPEG MB.
robdog1969
Member - Posts: 29
Posted: January 07, 2006 at 2:01 PM / IP Logged
check it with a meter it will throw ground ...... 86 or 85 think 85 to the left  ...if it has 2 step locks there will be 3 relays
over 20 years of experience in the 12 volt industry
Mike M2
Platinum - Posts: 2,652
Posted: January 07, 2006 at 2:59 PM / IP Logged
You don't say what year, but it's 1999 and earlier that you can tie into the relays. They are located on the front of the fuse box. It's the terminal closest to the passenger side....
Mike M2
Tech Manager
CS Dealer Services
ctc345
Member - Posts: 11
Posted: January 07, 2006 at 3:15 PM / IP Logged
thanks a million guys.dodge caravan door lock relays - Last Post -- posted image.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
