Alarm/ Starter 2002 Neon
b-roy
Copper - Posts: 56
Posted: January 18, 2006 at 6:08 PM / IP Logged
Hi all, recently put a Compusar alarm/starter combo in my '02 Neon. After the initial install I had a problem with the alarm falsing after remote start. The door pin wires would drop voltage, about 4-5 volts with the park light flash and this would set the unit off. To combat this I used the doorpin wire to trigger a relay instead getting rid of the problem, but.........
Now my dash lights do not work unless I open the door Alarm/ Starter 2002 Neon -- posted image.
Wondering if anyone had some thoughts before I get into it again.
mike swanson
Copper - Posts: 290
Posted: January 18, 2006 at 6:31 PM / IP Logged
may want to use a diode ?????
b-roy
Copper - Posts: 56
Posted: January 18, 2006 at 6:40 PM / IP Logged
Wires were diode isolated prior to the install of the relay and still are. Unless you mean in a different way........
cntrylvr79
Silver - Posts: 582
Posted: January 18, 2006 at 7:03 PM / IP Logged
Have you checked all the fuses?  Had something like that happen turned out a fuse blew.  Don't remember where or which one it was sorry.
Cause I'm So white and nerdy...
First Class Certi-fried installer
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
