Adding Remote Start to Factory Alarm?
carguy411
Silver - Posts: 683
Posted: January 20, 2006 at 8:25 AM / IP Logged
did anyone ever add a remote start to a factory alarm?? i have someone who hasa 06 envoy and doesnt really car about a full featured alarm jut wants the R/S
can i do that
sk8ingsmurf
Copper - Posts: 198
Posted: January 20, 2006 at 8:38 AM / IP Logged
Yes you can, they sell remote start only units, most alarm manufacturers have one or two independent remote start systems.  And if Im not mistaken I believe there are a few out there that are designed to be added to your factory alarm so you dont have to use two remotes.  Anyway if you post back here with your car year make and model Im sure someone can help you find out if your manufacturer has an in house remote starter, as most of the big ones do have an option for that these days.
KarTuneMan
Platinum - Posts: 7,056
Posted: January 20, 2006 at 9:19 AM / IP Logged
06 Envoy.....is what he said in his post. Most manufactures have stand alone R/S. Im not sure if your talking about using the factory transmitters for the remote start ??? Astro, Compustar, DEI, and AST.  pick one!
97f150ext
Copper - Posts: 104
Posted: January 20, 2006 at 9:27 AM / IP Logged
about two days ago I put an Avital 4000 on a factory alarm.  Whatever remtoe start you get all you have to do is hook up the negative remote start input to a negative pulse (as door lock output).  With two presses of the unlock on the factory keypad, the car would start.  Actually is easy since you dont  have to mess with installing as many wires as you would a straight up remote start install.
sk8ingsmurf
Copper - Posts: 198
Posted: January 20, 2006 at 12:23 PM / IP Logged
Sorry I didnt notice the 06 envoy part of his first post, it was early (only up at that time because of a 9.a.m class).  sounds like 97f150 did what I was talking about.  I do know that GM offers at least one factory remote start system with the factory remote and everything, I actually think they have a few different ones.
Mike M2
Platinum - Posts: 2,652
Posted: January 21, 2006 at 8:17 AM / IP Logged
I like the Pursuit As9075t. It connects to the motor legs just like a keyless uprade, so to start you press lock, unlock, lock.
Mike M2
Tech Manager
CS Dealer Services
carguy411
Silver - Posts: 683
Posted: January 21, 2006 at 11:41 AM / IP Logged
yeah i want to use the factory keyfob
now i still need the bypasses correct
i think i like the Pursuit As9075t Mike M2 was talking about.
which bypass should i get for it
thanks
carguy411
Silver - Posts: 683
Posted: January 24, 2006 at 5:11 PM / IP Logged
does anyone have more info on the Pursuit As9075t
i think they might want to go with that
thanks
Mike M2
Posted: January 24, 2006 at 6:30 PM / IP Logged
This is the same starter under the Prestige nametag...
http://www.amazon.com/exec/obidos/tg/stores/offering/list/-/B000AEIUVW/all/ref=dp_olp_1/103-7151968-6743822?_encoding=UTF8
Mike M2
Tech Manager
CS Dealer Services
kohara73
Copper - Posts: 192
Posted: January 24, 2006 at 7:06 PM / IP Logged
Why would you want to use factory remotes?  My factory remotes barely work from my front door to my driveway.  You could go with a R/S that is capable of arming and disarming factory security.  What good would R/S be if you can't be more than 30 feet from the vehicle?
Keith
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
