Best bypass module for a 2006 gmc sierra?
sahall32
Member - Posts: 11
Posted: January 27, 2006 at 8:28 AM / IP Logged
I see alot of modules for this truck. Has anyone used any of them without any issues?
Steve
mike swanson
Copper - Posts: 290
Posted: January 27, 2006 at 9:18 AM / IP Logged
The GM-SL is so easy to install you wont have to cut any of your wires. It will run the locks, seat heaters, defrost, Park lites, And by pass the key
also RAP shut down, OEM alarm
kgerry
Platinum - Posts: 3,455
Posted: January 27, 2006 at 2:50 PM / IP Logged
i think i have used all of them without any issues... for bypass only i'd go with the old faithful 555L ( as opposed to the 556L ) or a PLJX or GMBP....
for bypass and integration go with the 457G..... GMDLBP, etc.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
notoriouswill
Member - Posts: 32
Posted: January 29, 2006 at 1:01 AM / IP Logged
I have used both the GM-SL and the 457G......If it is just basic that u want go with the 457G if you have factory seat heaters and rear defrost go with the   GM-SL. That is my opinion.
1 Memphis Mojo 15
1 Memphis 4000 watt amp
1 Memphis 75watt 4 channel amp
2 Memphis 6.5" MSQ's
Best bypass module for a 2006 gmc sierra? - Last Post -- posted image.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
