can my amp handle this?
gi jesus
Member - Posts: 39
Posted: January 28, 2006 at 5:21 PM / IP Logged
i have an alpine 3546 amp currently running 2 alpine typ-e 10'' subs. i cant seem to find any specs on this amp and i was wondering if i could add another 2 10'' subs to it. Right now the subs are wired together for 2ohm load and the amp is bridged. if i wire 2 subs each  for 2 ohm and wire them up seperatly (ie 2 subs on left ch, 2 subs on right ch)willl this amp handle this kind of wiring set up?
'92 ford ranger
2 swe-1041 alpine 10"s
1 Vented enclosure
1 alpine 9811 HU
1 kenwood kac-8152d
fingaz22
Silver - Posts: 410
Posted: January 28, 2006 at 7:48 PM / IP Logged
if that amp is handling 2 ohms bridged right now. witch doesn't seem right. but if true, then the amp in stereo could handle 1 ohm each channel.
so 2 ohm stereo is fine but i wouldn't go any lower than 2 ohms and would keep it well ventalated and cool.
JUST ONE MORE AMP!!!
hu,alpine cva 1005/dva 5205
sound processor,symmetry(first one).
sub amp,power 1000 the terminator.(1992).
subs,spl comp dual 1 ohms.
punch 150hd on a 10" ev.
alotofhighs
forbidden
Platinum - Posts: 5,352
Posted: January 28, 2006 at 8:09 PM / IP Logged
That is a old amp if that is the full model #, not made in Japan IIRC. Does it have a blue stripe across it with white writing by chance? Black heatsink? If so, it is a 2 channel that was not designed to operate at 2 ohm mono. It will however handle 2 ohm stereo, so 2 pairs of svc 4 ohm subs wired in parallel will be good to go.
gi jesus
Member - Posts: 39
Posted: January 29, 2006 at 9:53 PM / IP Logged
yeah its black with a blue stripe across it and white writing. it does kick into protection now and again if i drive it too hard, but thats not very often b/c the 2 subs i have sound very good with the volume at about 15 on my h/u
but does anyone have a link of any other information on this amp, i cant seem to find any info on it . what i would really like to get is trhe owners manual for this relic. but this amp has been a great workhorse for me and it seems to be working fine :)
'92 ford ranger
1 Vented enclosure
1 alpine 9811 HU
1 kenwood kac-8152d
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
