2004 Silverado 2 dr V6
holtonch
Posted: February 01, 2006 at 2:26 AM / IP Logged
I am looking for the complete wiring color codes for a remote start system for my friends 2004 silverado 2 dr V6 including the passlock info Please!
notoriouswill
Member - Posts: 32
Posted: February 01, 2006 at 10:37 PM / IP Logged
12volts      red (x2)       +       ignition harness
Starter      yellow       +       ignition harness
Second Starter      N/A
Ignition      pink       +       ignition harness
Second Ignition      white       +       ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition      N/A
Accessory      orange       +       ignition harness
Second Accessory      brown       +       ignition harness
Keysense      lt. green       -       ignition harness
Power Lock      use Directed module 457GW
Notes: If Directed module 457GW is not available, refer to DirectFax document 1601.
On base model trucks, the 457GW is not necessary. Instead, the lock wire is lt. blue (-), pin B5, and the unlock wire is white (-), pin B10. They are in the lt. blue plug at the BCM.
Power Unlock      see power lock
Lock Motor      gray       5wi      driver door module in door
Unlock Motor      tan       5wi      driver door module in door
Parking Lights+      brown       +       driver kick panel
Parking Lights-      gray/black       -       BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards      white       -       steering column, 5 pin plug
Turn Signal(L)      dk. green       +       steering column, 5 pin plug
Turn Signal(R)      lt. green       +       steering column, 5 pin plug
Reverse Light      lt. green       +       BCM, black plug, pin F
Door Trigger      gray/blk (L), BLACK/ wht (R)       -       each door module in each door
Notes: On base model trucks the door trigger wires are in the lt. blue plug at the BCM, pins B4 and A5. On 4dr trucks the LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2. They are in the purple plug at the BCM. Use all wires and diode isolate.
Dome Supervision      gray/black       +       BCM, black plug, pin E
Trunk/Hatch Pin      N/A
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      arms with lock
Factory Alarm Disarm      lt. green       -       driver door module in door
Disarm No Unlock      see factory alarm disarm
Tachometer      white       ac       instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The tach wire is in the green plug, pin 10.
For tach can also go to any of the ignition coils or injectors and use the wire that is NOT pink, black, or brown.
Wait to start      dk. blue       -       instrument cluster, pin A2 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The wait to start wire is in the green plug, pin 36.
Brake Wire      white       +       brake pedal switch
Parking Brake      lt. blue       -       BCM, lt. blue plug, pin A7
Horn Trigger      BLACK / YELLOW to black       -       steering column
Memory Seat 1      red       +       driver door module in door
Memory Seat 2      pink       +       driver door module in door
Memory Seat 3      N/A       +
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Not required if using the combo interface module. The Passlock II wire colors are yellow, black, and RED / white (not used).
Combo Interface      Required:
Yes      Type:
Data Bus
Part #: 457GW
Notes:
If you use a 457G which is a DEI product you do not need any of the passlock wires not do you need to tap into any doorlock wires.
1 Memphis Mojo 15
1 Memphis 4000 watt amp
1 Memphis 75watt 4 channel amp
2 Memphis 6.5" MSQ's
2004 Silverado 2 dr V6 - Last Post -- posted image.
autotek27
Member - Posts: 6
Posted: February 09, 2006 at 6:16 PM / IP Logged
MODEL       YEAR(S)
FULL SIZE PICKUP (NEW BODY STYLE)       2003 -2006
KEY       T-HARNESS       IMMOBILIZER
N/A       GM-12       GM's PASSLOCK 2 ANTI-THEFT System, Requires 791 Bypass Module
PART       COLOR       LOCATION
12 VOLT CONSTANT       RED (+)       IGNITION SWITCH HARNESS
STARTER       YELLOW (+)       IGNITION SWITCH HARNESS
STARTER 2       N/A
IGNITION 1       PINK (+)       IGNITION SWITCH HARNESS
IGNITION 2       WHITE (+) See NOTE *6       IGNITION SWITCH HARNESS
IGNITION 3       N/A
ACCESSORY /HEATER BLOWER 1       ORANGE (+)       IGNITION SWITCH HARNESS
ACCESSORY /HEATER BLOWER 2       N/A
KEYSENSE       N/A
PARKING LIGHTS ( - )       GRAY/BLACK (-)       @ BCM, BROWN or TAN Plug, Pin B2, See NOTE *1
PARKING LIGHTS ( + )       N/A
POWER LOCK       See NOTE *4       See DIAGRAM
POWER UNLOCK       See NOTE *4       See DIAGRAM
DOOR TRIGGER       GRAY/BLACK (-) and BLACK/ WHITE (-) Use both, See NOTE *2       @ DOOR MODULE in each Front DOOR
DOMELIGHT SUPERVISION       GRAY/BLACK (-)       @ DRIVERS DOOR MODULE in DOOR
TRUNK RELEASE       N/A
SLIDING POWER DOOR       N/A
HORN       BLACK / YELLOW (-)       @ Comming from the TOP of the Steering Column
TACH       WHITE, See NOTE *7       @ PCM, GREEN plug, Pin 10, See NOTE *3
WAIT TO START LIGHT       See NOTE *5
BRAKE       WHITE (+)       @ SWITCH ABOVE BRAKE PEDAL
FACTORY ALARM DISARM       LIGHT GREEN (-)       @ DRIVER DOOR MODULE in DRIVERS DOOR.
ANTI-THEFT       YELLOW (+), BLACK (-) and RED / WHITE (Not Used)       GM's PASSLOCK 2 System, wires are in Ignition Switch Harness
EXTRA INFORMATION
NOTE *1 The BCM (Body Control Module) is located JUST below the Steering Column of the vehicle, the BCM has (3)Plugs facing the cab of the vehicle. The (3) Plugs are WHITE, BROWN or TAN and LIGHT BLUE. The 4th Plug, a PURPLE is located on the Back of the BCM. NOTE *2 On BASE model vehicles the DOOR Triggers are at the BCM in a LIGHT BLUE Plug, the DRIVER DOOR is a GRAY/BLACK (-) Pin B4, the PASSENGER DOOR is a BLACK/ WHITE (-) Pin A5. On all other trucks these wires are in each DOOR MODULE in each door. On the 4-door the DRIVERS rear door is LIGHT BLUE/BLACK (-) Pin A3, the PASSENGERS rear door is a LIGHT GREEN/ BLACK (-) Pin A2 in the PURPLE Plug. When connecting to an ALARM SYSTEM, you must DIODE ISOLATE these wires, See DAIGRAM NOTE *3 The PCM (Powertrain Control Module) is located in the LEFT FRONT of the engine compartment to the left of the fan shroud. NOTE *4 this vehicle uses a Special Multi-plex Type Door Locking System that will require (4) Extra Relays Part # 775, to do the Door Locks, See DIAGRAM NOTE *5 when hooking up a REMOTE STARTER on a DIESEL, if the WAIT to START wire from the Remote Starter does not wait until the Light on the dash turn out before cranking, you will need to program in the 5,10 or 15 Second WAIT to START TIMMER in the Installation Manual. On some vehicles the Wait to Start Light on the dash is not a true (+)Positive or (-)Negative and the wire from the Remote Starter will not owrk. When this Wait to Start Timmer is programmed, disconnect and tape up the Wait to Start wire from the Remote Starter that is tied into the Wait to Start Light on the dash. NOTE *6 IMPORTANT !!!!! this wire MUST BE CONNECTED as IGNITION #2 for REMOTE STARTING!!!!!! NOTE *7 On DIESEL ENGINES the TACH is WHITE in the BLACK Bottom plug, Pin 37 on the HYBRID the TACH is in a GREEN Plug, Pin 35
b-(
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
