Highlander Immobilizer Bypass
viewfarm15
Member - Posts: 6
Posted: February 02, 2006 at 10:48 AM / IP Logged
I am trying to install a remote starter in a 2001 Toyata Highlander.  I have reached a point where I need to bypass the coded key and have to install an Immobilizer Bypass Module.  I am trying to locate the "data", "clock" and "synch" wires from the ignition to the ECM.  Does anyone have the wiring diagram for these?
geepherder
Platinum - Posts: 3,668
Posted: February 02, 2006 at 10:56 AM / IP Logged
"When using the 555XW, the synch wire is gray, clock wire is pink, data wire is gray/blue, ignition wire is white, and ground wire is WHITE/ black."
viewfarm15
Member - Posts: 6
Posted: February 02, 2006 at 11:09 AM / IP Logged
Thanks for the speedy reply.  I have the same info from the install sheet that came with the immobilizer (model 555x).  Unfortunately I can't find any such colored wires coming from the ignition switch on the column.  I have a 6 pack harness that has the wires for hooking up the main remote.  Then I have a 4 wired harness right next to the 6-pack that has 2 yellow/black wires, a blue/grey wire and a pink&blue/grey wire.  Can you tell me where I should look for the gray, pink, gray/blue wires as it relates to the six pack harness?
Thanks, Ken
geepherder
Posted: February 02, 2006 at 12:28 PM / IP Logged
It should either be a harness close to the ignition harness with small wires (maybe 20 gauge or smaller), or at the diagnostic plug, but test to be sure.  Also check the instructions of your interface piece- it should say where to look.
viewfarm15
Member - Posts: 6
Posted: February 02, 2006 at 1:44 PM / IP Logged
Hi Geepherder!
I'm still not having any luck.  I can't find any harness with "gray, pink, and gray blue wires".  I have checked all around the ignition harness and the diagnostic plug for them.  The "instructions" just give me the same color scheme and the steering column.  I've also checked by the ECM with no luck.  Sure would appreciate some new ideas.  I see 4 small wires next to the ignition harness, but they are yellow/black (2), blue/grey and pink&blue/grey bands.  How do I test them if I'm stuck with trying these.
Thanks, Ken
geepherder
Posted: February 02, 2006 at 6:35 PM / IP Logged
Usually it tells you how to test for function.  You can try tech support, or post this in the alarm forum.  Many times the wires are there, but are nearly impossible to find.  They may be bundled together in tape, a vinyl sleeve, or something like that.
tjdurham
Copper - Posts: 180
Posted: February 03, 2006 at 12:03 AM / IP Logged
pull the cover off around the ignition switch  the wires change colors at a connector the wires you are looking for are coming off the transponder antenna ring which surrounds the keyswitch have fun programming the bypass take your time but not too much time while pushing gas pedal
tj
viewfarm15
Member - Posts: 6
Posted: February 03, 2006 at 8:24 AM / IP Logged
Still problems - but different this time.  I have been able to start the Highlander with the remote start.  Now I can't get the gear shift out of park ( with or without the key).  I probably screwed up the soldering at the brake pedal light switch.  Certainly no good now since I can't get the car out of Park - even without the remote starter.  Any ideas are appreciated.
geepherder
Posted: February 03, 2006 at 10:01 AM / IP Logged
Does the remote start die when you step on the brake?  If not, then you may have blown a fuse, which would cause it not to shift out of park.  Your brake lights will not work, either.
viewfarm15
Member - Posts: 6
Posted: February 03, 2006 at 10:14 AM / IP Logged
Hi Geepherder
The Remote Start dies when I step on the brake.  The brake lights work.  All of this seems to be working "right" - but I can't get the  car out of PARK - with or without the remote start or keys.  Sure am stuck now.
Ken
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
