Program a remote for 791xv
stonecole
Copper - Posts: 50
Posted: February 08, 2006 at 12:59 AM / IP Logged
Do anyone have info on programming another remote for the viper 791xv. Just bought a used remote need to find out how to program it. I have the original remote, needed a second remote.
Any help is appreciated. Thanks in advance.
turbo6
Posted: February 08, 2006 at 3:11 AM / IP Logged
Open the door
turn the ignition on to the on position
press the valet/programming button 2 time and hold it on the 2nd push
you will hear a long confirmation chirp
press the arm button on the new 2-way and you will hear one chip
you will hear a confirmation chirp when the remote button is pressed
turn the ignition off
done
stonecole
Copper - Posts: 50
Posted: February 08, 2006 at 10:34 AM / IP Logged
Thanks turbo6, I'll give that a try.
wranglercory
Copper - Posts: 53
Posted: February 08, 2006 at 10:52 AM / IP Logged
let us know if you still are having problems programing those remotes are well known to have cold solder joints on the circuit boards
stonecole
Copper - Posts: 50
Posted: February 08, 2006 at 10:57 AM / IP Logged
I never tried programming yet. This will be my first time programming this remote. But you said these remotes are known for having cold solder joints?
P.S. my remote should come in a day or two, bought it on ebay. If it don't program, I'll let you know.
Thanks for the heads-up.
stonecole
Copper - Posts: 50
Posted: February 11, 2006 at 2:34 PM / IP Logged
Received my remote today and programmed it as described above by turbo6. Excellent! works like a charm.
Thanks for the replies.
P.S. No problems as of yet Wranglercory.
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
