Old Setup And The New one
cubinbob
Member - Posts: 43
Posted: February 11, 2006 at 5:58 PM / IP Logged
On the old setup i used to run 3 mofo 15's. 3 1800 D class power acoustik amps for the subs one four channel and one 2 channel for the mids and highs. Two pairs of component sets and two pairs of 4x6 All of that was pushed by 5 optima yellow tops. Custom build fiberglass consol that hold 2 6.5 and 2 tweeters along with the head unit. I relocate the head unit so i can run a dvd touch screen up front. After the consol was done I decided to build an enclosure to hold 2 pairs of 4x6 so I can have rear fill sound. Custom built tweeter pods for the doors components. All of this was inside a four door dodge neon. Pictures of new setup coming soon. Sorry that I did not take any pictures during the fiberglass. Picture bellow.
Old Setup And The New one - Last Post -- posted image.
kirktcashalini
Silver - Posts: 492
Posted: February 12, 2006 at 3:53 PM / IP Logged
DAMN, is the new system as Big as that one. That thing must make you forget what you are thinking about.
sir_misery
Member - Posts: 23
Posted: February 12, 2006 at 9:04 PM / IP Logged
please tell me its for compitition only , not an every day driver right? can you hear me now? looks good tho
yeh? i can do that?
see! told ya!
cubinbob
Member - Posts: 43
Posted: February 12, 2006 at 9:55 PM / IP Logged
Already. Yep that was a daily driver. The only reason why I changed the setup was because of the weight and I did not want to upgrade to airbags or air struts. Was bumping hard. The new setup consists of only 2 1800 D class power acoustik amps links into one that pushes out around 3000 rms 2ohm to 4ohm. All that power is being used by 3 10 inch Power Acoustik fx series subs (800rms dual 4 ohm each) in a ported box that 2.6 cubic feet. Big change from 10.2 cubic feet from the last setup. I still ended up using four batteries in the back. For mids amp I only kept the four-channel amp to run the components in the consol and the doors. Had to get rid of the 4x6 consol because now a finally have a back seat. Let me tell for that small of a box and the subs being 10s I am very very impressed. I can not figure out how to post the new pictures. Please help so i can post them
cubinbob
Member - Posts: 43
Posted: February 12, 2006 at 11:18 PM / IP Logged
cubinbob
Member - Posts: 43
Posted: February 15, 2006 at 7:42 PM / IP Logged
it is not shared. one chamber two ports one sub
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
