Are there any aftermarket Keyless systems
ecin
Member - Posts: 9
Posted: April 08, 2006 at 8:40 PM / IP Logged
Are there any aftermarket keyless systems? I'm not talking about Remote entry. I mean keyless entry. Thanks
mo12v
Posted: April 08, 2006 at 8:57 PM / IP Logged
Passive Keyless Entry:
Try:
http://www.semiconductors.philips.com/applications/automotive/vehicle_access/rke/index.html
MO
john ogrady
Copper - Posts: 82
Posted: April 08, 2006 at 9:02 PM / IP Logged
There is all different types of keyless entry systems depending on the technolgy you want. There is the remote type Audiovox has one APS45B.There is also a tap type in which you can tap on your drivers window a certain sequence like a rhyme of music.There is also combination type in which press buttons on a numric keypad.With a one-way satellitte module you can use any touch tone telephone to un-lock your doors,arm the alarm even activate the remote start.
ecin
Member - Posts: 9
Posted: April 08, 2006 at 10:23 PM / IP Logged
oh okay, that's what it's called. Passive Keyless Entry. Thanks
Sunday, June 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
