galaxy 5000-rs
tnez2
Member - Posts: 26
Posted: April 11, 2006 at 9:21 AM / IP Logged
Hi I have a galaxy 5000rs -2 way on my 2001 ford ranger and i wanted to install a microwave sensor how do i go about this. do i just put it in series with the shock sensor with diodes? also i wanted to put a pin switch on my tool box, do i also run it to the hood switch with a diode.
Twelvoltz
Platinum - Posts: 2,384
Posted: April 11, 2006 at 9:35 AM / IP Logged
You have answered your own questions. Yes, you would diode isolate the connections, and tap them into your alarm's negative trigger inputs.
tnez2
Member - Posts: 26
Posted: April 11, 2006 at 9:56 AM / IP Logged
Hi just one more question. ok witch way do i install the diode, srtip to the sensor and switch? I was looking at the basic diode chart and it confused me a little. thanks
Powermyster
Silver - Posts: 962
Posted: April 11, 2006 at 10:05 AM / IP Logged
the stripe side block positive and black side block neg
Why oh Why didn't i take the blue pill
Darren Power
Twelvoltz
Posted: April 11, 2006 at 10:15 AM / IP Logged
You want the negative to flow only from the device to the alarm, not from device to device. (same as the multiple door trigger example given on the diode page)
Hope this clears it up a bit for you.
tnez2
Member - Posts: 26
Posted: April 11, 2006 at 10:40 AM / IP Logged
Thanks that cleared things up. i guess i had a brain fart.
Saturday, June 8, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
