Neutral safety switch 05 Silverado manual
derieux82
Posted: April 25, 2006 at 11:10 AM / IP Logged
   I installed a remote start on an 05 silverado with a manual transmission but i need to bypass the neutral safety switch and was wondering how to do that because it has 6 or 7 wires going to it unlike the 2 wire ones im used to.  I installed it to where it wont remote start unless the parking break is on so safety isnt an issue.  So all thats left is to bypass the neutral safety switch and was wondering how to do that.  Thanks!
JWorm
Platinum - Posts: 2,208
Posted: April 25, 2006 at 11:34 AM / IP Logged
^^^ That was a joke, right?
Do you really think having the parking brake on is going to prevent the truck from moving if you remote start it in gear? Don't believe me....try it once you get everything figured out.
And you are looking to bypass the clutch switch....not the neutral safety switch. There is no neutral safety switch. It is also against this forum's rules to tell you how to do what you are doing.
ZipPhReaK
Copper - Posts: 57
Posted: April 25, 2006 at 12:42 PM / IP Logged
I really hope you have a RS designed for Manual Transmissions... (Ex. Ultrastarters. Compustar.) They have an idiot proof reservation mode feature (if brain is installed correctly by a professional), which makes you put the car in neutral, and set the parking brake. You leave the car, it stays running, when you close the door it shuts off and is now allowed to RS.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
