Dodge Magnum Box Suggestions
Melted Fabric
Silver - Posts: 509
Posted: June 27, 2006 at 9:56 PM / IP Logged
From the look of it, he probably just had it sitting in there since it conformed to the shape of the space, the weight and shape probably holds it in place.
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
austincustoms
Copper - Posts: 232
Posted: July 10, 2006 at 12:32 PM / IP Logged
I would duplicate the Directed Electronics magnum box.  I'ts not really space efficent, but it's hella cool.
http://www.directedsnakepit.com/pit_car_info.asp?CarID=3
Flakman
Copper - Posts: 365
Posted: July 10, 2006 at 2:47 PM / IP Logged
magnumboy22 wrote:
yup..thanks for all the input....but i wont be able to put them in the rear pockets. the 12"'s are too big to fit back there. i had a guy at a custom shop check it out yesterday. :-( check this out... these are 10's in the rear pockets
If you are willing to go out of flush a couple of inches, the 12s will fit without a problem...and still look good. My question would be whether or not you have enough air space behind it. With a little creativity, you can cover that as well.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
