Sorry about that, here it is:
12volts black (30A), orange (7.5A) + ignition harness
Starter blue + ignition harness
Second Starter gray + ignition harness
Ignition yellow + ignition harness
Second Ignition pink + ignition harness
Third Ignition N/A
Accessory white + ignition harness
Second Accessory N/A
Keysense blue - ign harn or BECU, 10 pin plug, pin 5
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
The Body ECU is attached to the back of the fuse box under the driver side dash.
Power Lock brown - driver kick, 25 pin plug, pin 16
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock gray (double pulse) - driver kick, 25 pin plug, pin 8
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is gray (-) at the fuse box, top L, 16 pin plug, pin 7.
Lock Motor white to red 5wi driver kick, 25 pin plug, pin 9
Unlock Motor gray to white 5wi driver kick, 25 pin plug, pin 25
Parking Lights+ do not use, relay rests at gnd
Parking Lights- black - switch or BECU, 26 pin plug, pin 23
Notes: The Body ECU is attached to the back of the fuse box under the driver side dash.
Hazards white - switch or BECU, 16 pin plug, pin 4
Turn Signal(L) yellow + fuse box, middle, 12 pin plg, pin 12
Turn Signal(R) green + fuse box, L side, 12 pin plug, pin 9
Reverse Light red + driver kick, 17 pin plug, pin 9
Door Trigger see notes - see notes
Notes: The LF door is blue at the BECU, 26 pin plug, pin 24. The RF door is yellow at the BECU, 28 pin plug, pin 21. The LR door is lt. green at the fuse box, R side, 13 pin plug, pin 7. The RR door is gray at the BECU, 28 pin plug, pin 5 or 7. Use all four wires and diode isolate each.
Dome Supervision brown - fuse box, mid R, 12 pin plug, pin 5
Trunk/Hatch Pin white - dr kick or BECU, 28 pin plug, pin 25
Hood Pin red - hood pin switch under hood
Notes: Also found in a gray 25 pin plug to the right of the fuse box, pin 2.
Trunk/Hatch Release black 5wi dr kick or BECU, 26 pin plug, pin 1
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black ac data link conn. under dash, pin 9
Notes: Can also go to any fuel injector and use the wire that is NOT white.
Wait to start N/A
Brake Wire white to blue + sw or fusebox, L side, 12P plg, pin7
Parking Brake yellow or blue - parking brake switch
Horn Trigger white - sw or fuse box, rear 10P plug, pin 5
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
ASE Certified
