Different voltage batteries ran parallel
qnretail
Member - Posts: 32
Posted: June 30, 2006 at 10:23 AM / IP Logged
I have two 12v batteries and two 6v deep cycle batteries. The 6v batteries are ran together in series and then ran parallel with the other two batteries. My question is: Can I add a third 6v battery in series with the other two for a total of 18v and then if I run that parallel with the other two will it even out to 14v all around? Or will this damage the batteries?
2 x DD9515f's, Digital Designs Z1 amplifier
haemphyst
Platinum - Posts: 5,054
Posted: June 30, 2006 at 10:31 AM / IP Logged
No. Plain and simple. No. You'll FRY the 12 volt battery, AND your charging system can't charge an 18 volt battery, AND you'll fry your amps trying to run them off 18v. They're designed to run from 12-14 volts.
qnretail
Member - Posts: 32
Posted: July 02, 2006 at 4:26 PM / IP Logged
Thanks. I didn't think it would work but just thought I would ask.
Friday, May 3, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
