2006 Chevrolet 2500 HD Diesel Alarm/Remote Start Wiring
civic_tt
Member - Posts: 22
Posted: July 14, 2006 at 4:15 PM / IP Logged
Looking for a wiring diagram for a 2006 chev. 2500hd diesel full size pick-up.  Also any tips or secrets.  Thanks ERIK
josh1979
Silver - Posts: 320
Posted: July 14, 2006 at 9:38 PM / IP Logged
do not use wait to start wire it will result in check eng. light just use timer.
12volts
red (40A), red (40A)
ignition harness
Starter yellow  +  ignition harness
Second Starter N/A
Ignition pink  +  ignition harness
Second Ignition white  +  ignition harness
Notes: To avoid the check engine light from coming on and possible damage to the automatic transmission, the second ignition in this vehicle MUST be powered when adding a remote start system.
Third Ignition N/A
Accessory orange  +  ignition harness
Second Accessory brown  +  ignition harness
Keysense lt. green  -  ignition harness
Power Lock use Directed module 457GW
Notes: If Directed module 457GW is not available, refer to DirectFax document 1601.
On base model trucks, the 457GW is not necessary. Instead, the lock wire is lt. blue (-), pin B5, and the unlock wire is white (-), pin B10. They are in the lt. blue plug at the BCM.
Power Unlock see power lock
Lock Motor gray  5wi driver door module in door
Unlock Motor tan  5wi driver door module in door
Parking Lights+ brown  +  driver kick panel
Parking Lights- gray/black  -  switch or BCM, brown plug, pin B2
Notes: The BCM (Body Control Module) is under the driver side dash. It has 6 plugs in it, the purple plug is on the back.
Hazards white  -  hazard switch
Turn Signal(L) dk. green  +  turn signal switch
Turn Signal(R) lt. green  +  turn signal switch
Reverse Light lt. green  +  BCM, black plug, pin F
Door Trigger gray/blk (L), BLACK/ wht (R)  -  each door module in each door
Notes: On base model trucks, the door trigger wires are in the lt. blue plug at the BCM, pins B4 and A5.
On 4dr trucks, the LR door trigger is lt. blue/black, pin A3, and the RR is lt. GREEN/ black, pin A2. They are in the purple plug at the BCM.
Use all wires and diode isolate.
Dome Supervision gray/black  +  BCM, black plug, pin E
Trunk/Hatch Pin N/A
Hood Pin N/A
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms on lock with door open
Factory Alarm Disarm lt. green  -  driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer white  ac  instrument cluster, pin A5 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud.
On gas models, the tach wire is in the green plug, pin 10.
On diesel models, the tach wire is in the gray plug, pin 37.
On hybrid models, the tach wire is in the green plug, pin 35.
For tach can also go to any of the ignition coils or fuel injectors and use the wire that is NOT pink, black, or brown.
Wait to start dk. blue  -  instrument cluster, pin A2 or PCM
Notes: The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud. The wait to start wire is in the blue plug, pin 26.
On the remote start, make sure to program the Accessory State During Wait To Start to ON.
Brake Wire white  +  brake pedal switch
Parking Brake lt. blue  -  switch or BCM, lt. blu plug, pin A7
Horn Trigger BLACK / YELLOW to black  -  switch or BCM, gray plug, pin B9
Memory Seat 1 red  +  driver door module in door
Memory Seat 2 pink  +  driver door module in door
Memory Seat 3 N/A  +
2006 Chevrolet 2500 HD Diesel Alarm/Remote Start Wiring - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Passlock II
Part #: 556LW
Alternate Part1 #: 555LW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Not required if using the combo interface module. The Passlock II wire colors are yellow, black, and RED / white (not used).
Combo Interface
Required:
Yes
Type:
Data Bus
Part #: 457GW
Notes:
bring back the rotary phone so i dont have to press 1 to proceed in english
josh1979
Silver - Posts: 320
Posted: July 14, 2006 at 9:40 PM / IP Logged
12volts red (40A), red (40A)  +  ignition harness
Second Starter N/A
Third Ignition N/A
Trunk/Hatch Pin N/A
Hood Pin N/A
Memory Seat 3 N/A  +
Immobilizer Bypass
Required:
Yes
Type:
Passlock II
Part #: 556LW
Combo Interface
Required:
Yes
Type:
Data Bus
Part #: 457GW
Notes:
swamprat323
Gold - Posts: 1,335
Posted: July 14, 2006 at 10:10 PM / IP Logged
wait to start with a timer DEI 528T look at directfax 1091 it is the downlaod section under car alarms manurals
KarTuneMan
Platinum - Posts: 7,056
Posted: July 16, 2006 at 1:15 PM / IP Logged
Why not use the wait to start wire? (glow plug) if the unit is wired properly, there is NO better way to go. When that truck is warm, you can jump in turn the key and fire it off with NO waiting. Same would apply to remote starting. Why add another device to your install?
josh1979
Silver - Posts: 320
Posted: July 16, 2006 at 1:52 PM / IP Logged
you can not use the wait to start wire on these truck it will result in a check eng. light just like some fords. dont know why i just know u cant
Big Dog
Gold - Posts: 1,265
Posted: July 21, 2006 at 9:56 PM / IP Logged
Guys! Guys! No need for timers nor even a connection!
Control of the instant start system (ISS) glow plugs is accomplished by an electronic glow plug control unit and 4.7 volt glow plugs, requiring 2 seconds to heat up to 1,000°C (1,832°F). Most remote starters keep ignition on a couple of seconds before they crank.
But if you must: Glow Plug is Dark/Blue (-) pin A2 (next to a BROWN / White wire) at cluster.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Wednesday, May 22, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
