weird pats remote control problem
kruisecontrol
Member - Posts: 9
Posted: July 16, 2006 at 6:05 PM / IP Logged
hello , i have a 2000 ford expedition that i just got and im having a problem  ,it seems that someone installed a ignition cut off derived of the pats system ,it has a remote control  like this
weird pats remote control problem -- posted image.
i have to press the upper button once and the red theft light in the cluster goes off normally when i try to start the car and the car fires normally , once the car shuts off it rearms in 45 secs and if i dont press it before i try to start the car the theft light just blinks and the car wont start  , i looked everywhere for a bypass module or a remote starter or something that looks aftermarket but i cant find none and there is not even signs that the car had an alarm before, no wires cut or nothing,
is anybody familiar with this setup or has info on this , i need to take it out , thanks
kruisecontrol
Member - Posts: 9
Posted: July 17, 2006 at 3:30 PM / IP Logged
anyone? tips or ideas welcome
12voltmaster
Member - Posts: 38
Posted: July 17, 2006 at 4:03 PM / IP Logged
I never seen before the key fob you show, but is look like a key fob "transponder jammer" this vehicule have already transponder (PATS(passive antiteft system)) inside the key.
If your vehicule security light flashing rapidly in your dash board is means thats the vehicule factory security system is active. It cant also means the vehicule do not reconize the vehicule key. So is possible your system "jam" the factory transponder.
auex
Platinum - Posts: 5,041
Posted: July 17, 2006 at 4:10 PM / IP Logged
Replace the starter relay under the hood. The module is built into the relay.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
kruisecontrol
Member - Posts: 9
Posted: July 18, 2006 at 5:37 AM / IP Logged
it was there ,thank you much , its a very neat device , i wonder how its called and who sells them
misterjimbo
Silver - Posts: 535
Posted: July 26, 2006 at 9:42 AM / IP Logged
audiovox sells a similiar device, It is simply a remote controlled relay. The last time I checked it was only sold at new car dealers, but that may have changed
Sunday, May 5, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
