DEI CAN-1, 2006 VW Passat doorlock
12voltmaster
Member - Posts: 38
Posted: July 17, 2006 at 12:20 PM / IP Logged
I install DEI CAN-1 on a 2006 VW Passat and if I lock the door with the factory key fob I'm not able to unlock the vehicule doorlock with the CAN-1. I can only unlock the door when the vehicule is running.
Anybody have clue on this ???
reisset
Member - Posts: 38
Posted: July 17, 2006 at 1:08 PM / IP Logged
Evolution-UK
Copper - Posts: 192
Posted: July 18, 2006 at 11:42 AM / IP Logged
have you used the "factory alarm disarm and unlock" wires or just the unlock wires?
12voltmaster
Member - Posts: 38
Posted: July 18, 2006 at 2:17 PM / IP Logged
I'm not able to unlock and disarming factory alarm. I can only unlock the door when the vehicule is running.
12voltmaster
Member - Posts: 38
Posted: July 19, 2006 at 10:06 AM / IP Logged
I try both and doesn't work.
Is only disarm with transponder When I start the car.
Any idea !!!
Evolution-UK
Copper - Posts: 192
Posted: July 19, 2006 at 2:03 PM / IP Logged
it could be an incompatability with the 2006 vehicle. There is also an issue with 2006 Golf r32's but this is related to the tach wire dropping out.
12voltmaster
Member - Posts: 38
Posted: July 20, 2006 at 8:54 AM / IP Logged
I did something test with this car.... Is possible to disarm the factory alarm only with factory key fob not with a key inside driver door. Conclusion DEI CAN-1 for PASSAT 2006 is not compatible with this car... Sorry.
Thursday, May 2, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
