speaker ring sub mounting
blackers10
Posted: July 23, 2006 at 11:22 AM / IP Logged
hey guys
i just registered and have been reading all i can on fibreglass sub enclosures and have read heaps of threads on this here forum and am very greatful for all the helpful articles you guys have written!
but my question today is regarding the speaker rings
in all of the articles it shows the rings before the fleece is applied. then after the sub is installed. so cant see a picture to answer my question
my understanding is. you construct the speaker rings using the large and small rings ontop of eachother then lay the fleece and glass over it all except where the speaker hole is.
once this is done do you cut out the fleece/glass that is over the outter/higher ring then screw the sub to the un touched inner ring? is this what you refer to for flush mounting? as im not concerned wether the sub is flush or not (it is a pair of JL audio 15" 15w0 from memory (retail for $350AUD )
can you use just a single ring or will the fibreglass layed over the ring mess up the mounting surface hence why you state to use 2 rings?
hope you understand and can help there!
if sombody can post an image or even a mspaint picture of where the matting and fleece and mdf rings go that would be handy!!
just dont want to screw up my latest project (2x70ltr enclosures arnt cheap to build again!)
thanks fellas
sawhit4
Copper - Posts: 64
Posted: July 23, 2006 at 4:03 PM / IP Logged
Yeah you're right with flushmounting.  When you make the top ring, you make it as thick as your subs mounts to make sure it is flush.  But if you're not interested in flush mounting you can just make a single ring.  Thats what i did on my first project.  All you do fiberglass over it, then cut out the hole.  The reason most people dont put fiberglass over the hole is to save money and time, since you're just going to cut that part out later.  Heres a pic right after i cut the hole out.
speaker ring sub mounting - Last Post -- posted image.
Melted Fabric
Silver - Posts: 509
Posted: July 24, 2006 at 11:02 AM / IP Logged
Saw, what material is that around the piece in the picture. It looks soft, but I cannot think of the name of it. I am tired right now without a full breakfast too.
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
blackers10
Posted: July 24, 2006 at 11:04 AM / IP Logged
thanks matey
i cant wait to get my materials and start playing with it all!!
hard part is deciding what design to use
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
