1995 pontiac grand prix a/c wiring diag
ronjeremy85
Posted: July 25, 2006 at 8:27 PM / IP Logged
I have a 1995 pontiac grand prix se with some a/c problems. I have a haynes manual, but it has 16 wires labeled coming out of my hvac control unit; I have 20 wires. My selector switch is stuck on bi level defrost... and the switch is built into the control panel. does anyone have a wiring diagram for a 95 grand prix with manual temp control and a 3100 v6 engine? (prefer something not outta a Haynes book) Thank you
Jeremy
ronjeremy85
Posted: July 25, 2006 at 8:30 PM / IP Logged
Correction... HVAC wiring diagram... Thanks
shawnvw
Posted: July 25, 2006 at 9:10 PM / IP Logged
check under the hood for a vacuum leak
usually when the ducts are stuck on defrost, it is a vacuum leak. There should be a black, hard, plastic tube that goes into the wiring harness, that goes into the car on the passenger side.
ronjeremy85
Posted: July 25, 2006 at 9:50 PM / IP Logged
thanks... try that in the morning
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
