stereo problems
cygulf
Posted: August 07, 2006 at 10:24 PM / IP Logged
hi im new and was wondering if someone coupld help me install my cd player in my 1987 mazda 323...its causing me to have lots of problems...thanx
forbidden
Platinum - Posts: 5,352
Posted: August 07, 2006 at 10:36 PM / IP Logged
So, what are the problems? Velocity Motors borrowed my crystal ball and won't give it back and Madame Clara is out of town.
cygulf
Posted: August 08, 2006 at 4:40 PM / IP Logged
the deck doesnt power and ive checked both of the fuses in the car and the deck...
pss5075104
Copper - Posts: 144
Posted: August 08, 2006 at 4:50 PM / IP Logged
do you have a distrubution block under the hood, if so check fuses there. that is where the constant fuse is on some cars.
D
MECP First Class Certified Installer.
Nothing is impossable, it's just more expensive.
kgerry
Platinum - Posts: 3,455
Posted: August 08, 2006 at 6:21 PM / IP Logged
so did you meter both powers and ground right at the back of the HU?  and all was good?  that pretty much denotes a problem internally in the HU, doesnt it?
if my memory serves me correctly ( probably not after 9866 Coronas) the older Mazdas used a negative power antenna circuit, not a postive like most vehicles... check to make sure you havent zapped something on the remote/P Ant output....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
