amps classes
jonathangauci
Copper - Posts: 61
Posted: August 12, 2006 at 4:58 AM / IP Logged
l want to know l have an amp 1500 w class a\b if l buy another amp 1500 w but class d the same brand what is the diference more power what                                         thanks
conseit68
Member - Posts: 33
Posted: August 12, 2006 at 7:03 AM / IP Logged
someone correct me if i am wrong but the main difference bewteen a/b and d is how wattage is derived and class d amps run much cooler and more effienctly.
jonathangauci
Copper - Posts: 61
Posted: August 12, 2006 at 9:10 AM / IP Logged
ok l know but l want to know if class a/b puts less watts on a sub ezzample l have 1500 watts amp class a/b and l have kicker l7 the amp puts less watts
DYohn
Moderator - Posts: 10,741
Posted: August 12, 2006 at 10:29 AM / IP Logged
1500 watts is 1500 watts.  An amplifier's class describes the electrical circuitry used to produce those watts.
jonathangauci
Copper - Posts: 61
Posted: August 12, 2006 at 10:52 AM / IP Logged
ok thanks last quastion but if l buy 1500 class d there is no diference in bass hitting harder
killer sonata
Silver - Posts: 718
Posted: August 12, 2006 at 10:54 AM / IP Logged
the difference between a class A/B and a class D amp is the efficiency rating. A class D amp is much more efficient.
DYohn
Posted: August 12, 2006 at 12:32 PM / IP Logged
All that is true but it really doesn't matter to the SPL performance of a speaker system.  1500 watts output is 1500 watts output and it doesn't matter what amplifier topology produces it.
Now don't get me wrong, efficiency can be very important to the user, especially when considering upgrading the vehicle's alternator (which a 1500 watt class A/B amp will probably require while a 1500 watt class D or T amp may not.)  And, there are some significant SQ differences in the classes especially for mains, not so much for subwoofer amps.  But the original poster wondered if amplifier class by itself will produce differences in power output.  No, it will not.
killer sonata
Silver - Posts: 718
Posted: August 12, 2006 at 2:13 PM / IP Logged
Hey DYOHN, dont forget that eclipse and alpine have the new ICEpower D class amps that are slowly proving to be just as good for SQ as calss A/B
jonathangauci
Copper - Posts: 61
Posted: August 13, 2006 at 1:00 AM / IP Logged
ok thanks very much its  good forum thanks
Friday, May 10, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
