2006 Lexus GS300 alarm info
rikanman
Member - Posts: 16
Posted: August 18, 2006 at 3:52 PM / IP Logged
Does anyone have this information, thanks a lot. At least the starter kill info will help alot.
josh1979
Silver - Posts: 320
Posted: August 19, 2006 at 9:44 PM / IP Logged
 LEXUS / GS 300 / 2006 / Remote Start
12volts brown and orange (common 15A)  +  PSC ECU, 40 pin plug, pins 12 and 33
Notes: The PSC (Power Source Control) ECU is the module on the far right, behind the glovebox.
Starter blue  +  PSC ECU, 40 pin plug, pin 15
Second Starter lt. blue  +  PSC ECU, 40 pin plug, pin 17
Ignition yellow  +  PSC ECU, 40 pin plug, pin 35
Second Ignition lt. blue  +  PSC ECU, 40 pin plug, pin 34
Third Ignition N/A
Accessory green  +  PSC ECU, 40 pin plug, pin 11
Second Accessory N/A
Keysense N/A
Power Lock lt. green  -  power window master switch in door
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock pink (double pulse)  -  power window master switch in door
Lock Motor green  5wi driver door ECU in door
Unlock Motor red  5wi driver door ECU in door
Parking Lights+ green  +  headlamp assembly under hood
Parking Lights- multiplex from switch to ECU
Hazards orange  -  turn signal flasher near column
Turn Signal(L) green  +  turn signal flasher near column
Turn Signal(R) red  +  turn signal flasher near column
Reverse Light red  +  multi-display, 26 pin plug, pin 13
Door Trigger see notes  -  see notes
Notes: The LF door is red at the BECU (RH), 16 pin plug, pin 14. The RF door is red at the BECU (RH), 28 pin plug, pin 23. The LR door is green at the passenger side fuse box, 28 pin plug facing firewall, pin 11. The RR door is blue at the BECU (RH), 16 pin plug, pin 16. Use all four wires and diode isolate each.
The Body ECU (RH) is attached to the passenger side fuse box, behind the glovebox.
Dome Supervision blue  -  BECU (LH), 10 pin plug, pin 2
Notes: The Body ECU (LH) is attached to the driver side fuse box, under the driver side dash.
Trunk/Hatch Pin red  -  BECU (LH), 16 pin plug, pin 11
Hood Pin WHITE/ blue  -  hood pin switch under hood
Trunk/Hatch Release lt. green  -  BECU (LH), 16 pin plug, pin 13
Notes: Meter this wire while opening the trunk from the handle on the trunk.
The fuel lid release is purple (+) at the driver side fuse box, gray 30 pin plug, pin 25.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock
Tachometer white  ac  data link connector, pin 9
Notes: The data link connector is under the driver side dash.
Wait to start N/A
Brake Wire RED / black  +  brake pedal switch
Parking Brake yellow  -  multi-display, 26 pin plug, pin 23
Horn Trigger yellow  -  horn switch in column cover
Memory Seat 1 blue  -  memory seat switch in door
Memory Seat 2 purple  -  memory seat switch in door
Memory Seat 3 red  -  memory seat switch in door
2006 Lexus GS300 alarm info - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: N/A
Notes: No information available at this time.
Smart Starter Kill Relays: Not Available
bring back the rotary phone so i dont have to press 1 to proceed in english
Tuesday, May 21, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
