110 to 12V in home car audio
tanktank
Posted: August 26, 2006 at 2:34 AM / IP Logged
ok, hey im new here, and basically thank god for this site. Through learning things ive read on here i have become facinated with audio/electronics. SO my situation:
I have a 500W 110 (wall plug) to 12V (positive, negative and ground contacts) converter which was used for a car audio system display (in house) at a ford dealership. I am trying to hook a little kenwood KAC-723 amp to my onkyo head unit via a "hi-lo" converter or low frequency crossover so i can hookup an extra sub i have laying around and use it to add some depth to my stereo.
My questions:
1. Is this possible at all given the different power sources? Does my HU for my house give out a different power than my crossover can use?
2. How do i need to hook the power from the power converter to the amp? My only personal source said i need to run the positive and negative to the power contact on the amp to complete the circuit, then hook the ground to the ground (obviously).
3. My hi-lo/crossover has a positve, ground and remote terminal. Does that mean i can hook the power from the amp into the X-over, then connect the remote terminals from the X-over to the amp, and leave the ground un-plugged as far as the x-over (the way it was being used inside the car it was taken from) is concerned?
As it stares me in the face everytime i sit at my computer, not working, my current connections with the system are as follows:
Sound signal:
HU>X-over>RCA's into amp
Power:
Power box positive and negative>positive contact in amp
Ground:
Power box ground>amp ground
X-over:
Both left and right positive and negative>positive and negative left and right contacts
X-over power:
Amp power contact>X-over power contact
I hope this made sense, LET'S MAKE THIS WORK!
You know it works when you turn it on an no one dies.
auex
Platinum - Posts: 5,041
Posted: August 26, 2006 at 8:30 AM / IP Logged
So you are trying to use a car audio amp with your home stereo right? If that is the case then it will cost alot to get a 110/120AC to 12VDC converter to power the amp. It would be cheaper to buy a home stereo amp to power the speakers then it would cost to get a good converter.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Hornshockey
Silver - Posts: 520
Posted: August 27, 2006 at 2:04 AM / IP Logged
if I'm correct in what I'm reading, you have a home receiver, a car amp and a 110VAC to 12VDC power supply.
You should be fine just hooking up the power and ground from the amp to the power and ground on the power supply.  Just jump the remote wire to the constant wire so the amp will be on whenever the power supply is on.  If your recevier has RCA outputs for a subwoofer amplifier, you can use those to input the signal to the car amp you've got.  If you don't have outputs, you can use an automotive LOC to get RCA inputs for your amp.
You should not have to use the ground contacts on the power supply.  Just use the positve and negative terminals.  That's the only correction I can see in your setup.  Just treat the power supply the same way you would a battery, hook up your positives to positive and negatives to negative
Life moves pretty fast; if you don't stop and look around once in a while; you could miss it.
tanktank
Posted: August 27, 2006 at 4:01 PM / IP Logged
hornshockey has it right.
so hook the positive from my power box to the positive on the amp, and hook the negative from the power box to the ground on the amp? and leave the ground out cause its grounded through the negative right?
tanktank
Posted: August 29, 2006 at 11:40 PM / IP Logged
ITS ALIIIIIIIIVE!!!!!! so rad. thanks for the help.
Installer_mss
Copper - Posts: 221
Posted: September 08, 2006 at 5:16 PM / IP Logged
be careful, this will turn on the amp but the power supply (convertor) probably doesnt put out enough amperage to power the amp correctly.  if you continue to use it this way, especially if you turn it up any, it can damage the amp and the power supply.  if you want to use this amp this way instead of buying a home audio amp then get a deep cycle battery and a battery charger.  set the charger to like 15 or 20 amps or the closest setting to that and hhok the amp up to the battery the way you would in a car.  for the remote turn on just run it to the positive as well but put a small switch on it to turn it off while not in use.
"If a man made it, another can modify it...it just takes some thinking."
"If you ask questions, you're a fool for 5 minutes; if you don't, you're a fool for a lifetime."
jstruckman
Copper - Posts: 465
Posted: October 16, 2006 at 3:13 PM / IP Logged
Yeah, cuz a battery and a battery charger sitting in your living room looks so cool! There is no way you would need a 120 amp power supply for the little kenwood amp. And seeing you can get 500 watt 110-120volt home amps for under 200 bucks that would be the right way to do it and not make your living room look like the ghetto living rooms the people in Iowa have.
DYohn
Moderator - Posts: 10,741
Posted: October 16, 2006 at 3:37 PM / IP Logged
Using 12volt gear powered from 120V power supplies is never a very brainy idea, unless you are very careful to properly fuse your power supplies.  And as was stated above, 120V/12V power supplies with adequate power capacity for any high-power car audio amplifier are very expensive.  Using a raw battery and a charger is not safe if the battery is lead-acid, and you can easily blow your charger since most of them max out at 20 or 40 amps.
Bottom line is it is safer and cheaper in the long run to use gear designed for the home in the home and use gear designed for the car in the car.
Hymer
Silver - Posts: 695
Posted: October 16, 2006 at 11:05 PM / IP Logged
Any noise problems?   just curious... done it before similar setup... sometimes clear as abell other times lotsa hum...
Tire Proz Stillwater Mn
High End Restyling and Comlete Repair
larzzzz
Member - Posts: 10
Posted: December 17, 2006 at 7:40 AM / IP Logged
I did the same thing years ago with an a/d/s ph 15 using a Lambda Lab grade power supply that was rated 0-24 volts, 0-80 amps, that I got for a song. It sounded great, except that the ps filter cap in the pre-amp needed replacing. I replaced that cap and it made no noise whatsoever. I plan on doing it again to put tunes on my hot tub deck. Alpine 4v HU and perhaps some Paradigm speakers. The HU will have marine cover and will be cut into a heated towel closet.
Larzzzz
Been there, broke that... lmao
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
