How to wire a 4ohm dvc and 2 ohm dvc?
John64
Member - Posts: 30
Posted: September 06, 2006 at 2:31 PM / IP Logged
I currently run an Alpine MRV 1507  with an Alpine SWR 1522D.  How can I wire another sub, but this one is a SWR 1542D? What would your ideal wiring set up if you had my components?
John
aznboi3644
Gold - Posts: 2,600
Posted: September 06, 2006 at 3:20 PM / IP Logged
Why did you get a different impedance sub anyways???
Either one coil of the dual 2 ohm to one channel and parallel the dual 4 ohm to the other channel
Or....I dunno
KarTuneMan
Platinum - Posts: 7,056
Posted: September 06, 2006 at 6:21 PM / IP Logged
Alpine SWR 1522D I would use the ONE. yes 1 sub, dual 2ohm coils and wire it like this. At 4ohm mono that alpine should yeild 6 to 800 watts. Just make sure you have the reserve in your battery, and a decent alternator. Just My opinion.
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
How to wire a 4ohm dvc and 2 ohm dvc? - Last Post -- posted image.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
