2006 250 van
Welcome Guest :)
elprofessor36
Member -
Posted: September 17, 2006 at 4:02 PM / IP Logged
can some one help with the wiring diagram for a 2006 ford van 250 need to install an alarm thx
KarTuneMan
Platinum -
Posted: September 17, 2006 at 4:20 PM / IP Logged
MODEL | YEAR(S) |
ECONOLINE | 2004 -2006 |
KEY | T-HARNESS | IMMOBILIZER |
N/A | FD-2 | N/A |
PART | COLOR | LOCATION |
12 VOLT CONSTANT | (3) LIGHT GREEN/ PURPLE (+) | IGNITION SWITCH HARNESS |
STARTER | WHITE/ PINK (+) | IGNITION SWITCH HARNESS |
STARTER 2 | N/A | |
IGNITION 1 | PINK/LIGHT GREEN (+) | IGNITION SWITCH HARNESS |
IGNITION 2 | BLACK/ LIGHT GREEN (+) | IGNITION SWITCH HARNESS |
IGNITION 3 | | |
ACCESSORY /HEATER BLOWER 1 | GRAY / YELLOW (+) | IGNITION SWITCH HARNESS |
ACCESSORY /HEATER BLOWER 2 | RED (+) | IGNITION SWITCH HARNESS |
KEYSENSE | N/A | |
PARKING LIGHTS ( - ) | N/A | |
PARKING LIGHTS ( + ) | BROWN (+) | @ HEADLIGHT SWITCH |
POWER LOCK | RED (TYPE C) See NOTE *1 | IN EITHER KICK PANEL |
POWER UNLOCK | BROWN (TYPE C) See NOTE *1 | IN EITHER KICK PANEL |
DOOR TRIGGER | See NOTE *2 | @ EITHER DOOR PIN SWITCH |
DOMELIGHT SUPERVISION | BLACK/ LIGHT BLUE (+) | @ RELAY, to the RIGHT of the STEERING COLUMN |
TRUNK RELEASE | N/A | |
SLIDING POWER DOOR | N/A | |
HORN | DARK BLUE (-) | @ STEERING COLUMN HARNESS |
TACH | WHITE/ PINK | @ PCM, Pin 48, See NOTE *3 |
WAIT TO START LIGHT | N/A | |
BRAKE | DARK GREEN (+) | @ SWITCH ABOVE BRAKE PEDAL |
FACTORY ALARM DISARM | N/A | |
ANTI-THEFT | N/A | |
EXTRA INFORMATION |
NOTE *1 If vehicle has a FACTORY KEYLESS ENTRY, PINK / YELLOW is LOCK, and PINK/LIGHT GREEN is UNLOCK, it is a TYPE B Door Locking System, if vehicle is without a FACTORY KEYLESS ENTRY, it is a TYPE C System and you MUST TEST from the PASSENGERS LOCK/UNLOCK SWITCH this switch is the MASTER SWITCH.. NOTE *2 This vehicle has a door pin trigger for each door, the DRIVERS DOOR is a RED / PINK (-) the PASSENGER DOOR is a BLACK/ WHITE (-) and the SLIDING DOOR if equipped, is a WHITE (-) use all 3 DOOR TRIGGER wires and DIODE ISOLATE when connecting to an ALARM SYSTEM. To connect, See DIAGRAM NOTE *3 The PCM (Powertrain Control Module) is located under the hood, next to the Brake Master Cylinder. On Diesels the TACH wire is in Pin 1, top of plug, WHITE/ PINK wire. |
elprofessor36
Member -
Posted: September 17, 2006 at 6:06 PM / IP Logged
thx kartuneman appreciate it
Sunday, May 19, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
