How to test Disarm wire w/o Key cyclinder
black cavy
Copper - Posts: 78
Posted: September 18, 2006 at 6:44 PM / IP Logged
Key cyclinder.
I've notiched a lot of new cars/trucks etc,don't have a key holes anymore.Now i haven't come across this yet because i work on pre 2000 cars but i know i will sometime.
I know how to test for a disarm wire by using the key but don't know how to do it on new cars.
any help would be great
JWorm
Platinum - Posts: 2,208
Posted: September 18, 2006 at 7:48 PM / IP Logged
If it don't have a key cylinder, it proably won't have a disarm wire. Some new cars only disarm with the factory remote (GM's), while some will disarm by remote or by turning on the ignition. A bypass module may also disarm the alarm, as well as do the doorlocks. If you have a question on a specific vehicle, let us know which one.
black cavy
Copper - Posts: 78
Posted: September 18, 2006 at 10:07 PM / IP Logged
Thats neat to know,i never know that
Well i don't have spec car that im refering to but i've notiched alot of the European cars are like this
Audio i think
BMW
but some fords are that way now to along with the Chrylers and the new GM suvs
auex
Platinum - Posts: 5,041
Posted: September 18, 2006 at 11:19 PM / IP Logged
Some disable with key sense as well. It is still a case by case basis and you can find most disarm wires by looking up the wiring diagram as it will tell you if it is even available.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Chris Luongo
Platinum - Posts: 3,746
Posted: September 19, 2006 at 7:01 AM / IP Logged
I can't recall seeing any car with no key cylinder on the exterior at all. I mean, how would you get in if the car's battery died.
They've removed the passenger-side key cylinder from almost all new cars, and a lot of them don't have one on the trunk either......but there should certainly be one for the driver's door.
The Acura RL for example.....at least I think it was an RL......appears to have no key cylinders, but on the driver's side of the car, you can remove a decorative plastic cover, revealing the key cylinder underneath.
Mike M2
Platinum - Posts: 2,652
Posted: September 19, 2006 at 7:06 AM / IP Logged
2007 Corvette....
Mike M2
Tech Manager
CS Dealer Services
JWorm
Posted: September 19, 2006 at 9:15 PM / IP Logged
Audio i think
BMW
Every Audi has a key cylinder. On the A8 it is hidden. You have to lift up the handle and look behind it.
brianiac
Posted: September 30, 2006 at 1:50 PM / IP Logged
Actually my 2005 Corvette *does* have a external key, it's above the rear license plate that allows just for that.  Now being able to get into the vehicle due to a dead battery etc.
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
