2007 Toyota FJ Cruiser Audio/Alarm Wiring
Viper238
Posted: September 19, 2006 at 2:51 PM / IP Logged
audio wiring info..  mainly interested in the amp wiring in the rear quarter panel..
I found out on the audiovox site that that's where it is located.. but no specific info on signal or power..
The vehicle is able to have a amp and sub as I've been told..  I found the harness.. but haven't had time to try and figure out what is what..  I believe there is 7 or 8 wires in the plug..
Viper238
Posted: October 12, 2006 at 9:24 AM / IP Logged
Any updates?
eliteaudioplus
Posted: October 30, 2006 at 1:15 PM / IP Logged
any alarm diagrams for 07 toyota fj
Big Dog
Gold - Posts: 1,265
Posted: October 30, 2006 at 3:06 PM / IP Logged
Does this help?
Radio 12v
Radio Ground
Radio Ignition
Radio Illumination
Factory Amp Turn-on
Power Antenna
LF Speaker +/-
RF Speaker +/-
LR Speaker +/-
RR Speaker +/-
I don't know how to interface with the NXT roof liner flat panel speakers. http://www.nxtsound.com/index.php?id=648
Prepare your future. It wasn't the lack of stones that killed the stone age.
Big Dog
Gold - Posts: 1,265
Posted: October 30, 2006 at 3:10 PM / IP Logged
Here's the r-start info:
                                ITEM                                         WIRE COLOR                    POLARITY             LOCATION
12volts wht/blue (50A), blue/blk (30A) +  ignition harness
Starter GREEN/ black  +  ignition harness
Second Starter BLACK/ white  +  ignition harness
Ignition BLACK/ red  +  ignition harness
Second Ignition blue / YELLOW  +  ignition harness
Third Ignition N/A
Accessory WHITE/ green  +  ignition harness
Second Accessory N/A
Keysense GREEN/ YELLOW  -  ign harn or BECU, top plug, pin 14
Notes: Using the status output from the remote start to trigger this wire will disarm the factory alarm without unlocking the doors.
The Body ECU is attached to the back of the fuse box under the driver side dash. It has three plugs on the right side edge of the fuse box.
Power Lock blue  -  driver kick, 18 pin plug, pin 6
Notes: Meter this wire while turning the key in the driver door key cylinder.
Power Unlock pink (double pulse)  -  driver kick, 18 pin plug, pin 8
Also found at the BECU, bottom plug, pin 12.
Can also use the passenger door key cylinder unlock wire, which only requires a single pulse. It is YELLOW /GREEN in the passenger kick, 18 pin plug, pin 3 or at the BECU, bottom plug, pin 22.
Lock Motor blue/red to BLACK/ white  5wi driver kick, 13 pin plug, pin 8
Unlock Motor blue/black to BLACK/ red  5wi driver kick, 13 pin plug, pin 13
Parking Lights+ green  +  BECU, bottom plug, pin 28
Notes: The Body ECU is attached to the back of the fuse box under the driver side dash. It has three plugs on the right side edge of the fuse box.
Also found at the fuse box, 16 pin plug, pin 13.
Parking Lights- green  -  switch or BECU, top plug, pin 8
Hazards white  -  hazard switch
Turn Signal(L) blue/white  +  fuse box, 16 pin plug, pin 9
Turn Signal(R) pink  +  fuse box, 16 pin plug, pin 15
Reverse Light RED / yellow  +  fuse box, 16 pin plug, pin 10
Door Trigger purple / YELLOW (ajar indicator) -  BECU, top plug, pin 12
Notes: The individual door trigger wires are also available at the BECU, in the middle plug. The LF door is RED / black in pin 23. The RF door is GREEN/ YELLOW in pin 24. The LR door is pink/black in pin 11. The RR door is pink/blue in pin 12. Use all four wires and diode isolate each.
Dome Supervision white  -  fuse box, 20 pin plug, pin 8
Trunk/Hatch Pin white  -  BECU, middle plug, pin 7
Hood Pin N/A
Trunk/Hatch Release blue / YELLOW  5wi back door ECU, 25 pin plug, pin 13
Notes: The back door ECU is in the rear tailgate.
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer BLACK/ white  ac  data link conn. under dash, pin 9
Notes: Also found at the ECM (Engine Control Module) behind the glovebox, second plug from the bottom, pin 1.
Can also go to any ignition coil and use the wire that is NOT BLACK/ red, WHITE/ red, or WHITE/ black.
Can also go to any fuel injector and use the wire that is NOT BLACK/ red.
Wait to start N/A
Brake Wire GREEN/ YELLOW  +  sw or fuse box, 16 pin plug, pin 16
Parking Brake WHITE/ red  -  sw or fuse box, 24 pin plug, pin 1
Horn Trigger GREEN/ red  -  horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2007 Toyota FJ Cruiser Audio/Alarm Wiring - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
No
eliteaudioplus
Posted: October 30, 2006 at 3:51 PM / IP Logged
Thanks for the post.
netvoltage
Posted: November 25, 2006 at 6:22 PM / IP Logged
any info on the Nuetral Safety Switch wire for FJ Cruiser?
Sunday, May 26, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
