rca plug repair
sdg8569
Member - Posts: 9
Posted: September 21, 2006 at 10:24 PM / IP Logged
I just installed an amp and sub in my 02 silverado. The problem is that one of the rca plug ripped off when I pulled it thru the carpet. Can this be repaired or do I have to rip the hole thing out and install a new one? Its all wire tied and hidden. I was at the end of my install and bam right in the kisser. Man this is a tuff thing to take. Any help would be greatly appreciated. Thanks
G-Man
Bmnicolosi
Copper - Posts: 173
Posted: September 21, 2006 at 10:29 PM / IP Logged
cut off the broken plug, strip the outter shield back like an inch or so.  strip back the inner shield like 1/2 inch.  do the same with another rca with a good plug on it < use the plug end though>  connect inner to inner, tape off, connect outter to outter, tape off---make sure inner and outer dont touch.  make sense?
If you say "I already know how", don't ask me a single question.
Bmnicolosi
Copper - Posts: 173
Posted: September 21, 2006 at 10:36 PM / IP Logged
rca plug repair - Last Post -- posted image.
auex
Platinum - Posts: 5,041
Posted: September 21, 2006 at 10:45 PM / IP Logged
You can buy rca ends at radio shack. Just solder the inner conductor to the center pin of the rca and the shield/outer conductor to the outer pin of the rca.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
auex
Posted: September 22, 2006 at 8:39 PM / IP Logged
If it was a customer's vehicle then the correct action would be to replace the rcas. Since this is his personal vehicle then it is his choice. Also he stated he had zip tied the wires and it would definately take more then 10 minutes.
sprawl85
Copper - Posts: 204
Posted: September 22, 2006 at 9:53 PM / IP Logged
paint>Bmnicolosi
fiberglass reminds me of peanut brittle... but fiberglass tastes better!
sdg8569
Member - Posts: 9
Posted: September 23, 2006 at 11:16 AM / IP Logged
I replaced the rca cables. The audiobaun were junk. The wires were so thin it was not worth repairing them. Took about 45 min to hour to replace them.
Thanks guys!
G-Man
supradude
Silver - Posts: 915
Posted: September 23, 2006 at 1:09 PM / IP Logged
Audiobahn and junk. They mean the same thing don't they?
'85 Toy
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
