Wiring in immobiliser
davemonkey
Member - Posts: 12
Posted: September 26, 2006 at 2:06 AM / IP Logged
Alarm is a Toad A101CL with single point immobiliser that i'm fitting to my 1989 Austin Mini. I was going to make an immobiliser loop with the wire that goes from the starter relay to the starter solenoid. (The thickish brown one with the red stipe i think.)
Would this be ok? If not anyone got any ideas of what else i could use.
The reason i raised the query about using the wire from the starter relay to the starter solenoid is that it is quite a thick wire and the immobiliser wires are quite thin. Wondered if i ran the risk of burning them out? Any ideas?
Powermyster
Silver - Posts: 962
Posted: September 26, 2006 at 2:30 AM / IP Logged
better to immobilise fuel pump.. if the wires are too thin use a relay with it
Why oh Why didn't i take the blue pill
Darren Power
davemonkey
Member - Posts: 12
Posted: September 27, 2006 at 2:20 AM / IP Logged
I can't use the fuel pump sadly because it's mechanical! (Runs off the camshaft). Any other ideas? I'm not too bad with wiring but any advice appreciated.
Moderator - Posts: 12,488
Posted: September 27, 2006 at 8:29 AM / IP Logged
Aside from the starter you can immobilize the ignition wire.
davemonkey
Member - Posts: 12
Posted: September 28, 2006 at 2:09 AM / IP Logged
Is it ok to immobilise a wire if it's quite thick though, wondered about how much juice goes through it? Like i said in the earlier post, wondered if there was a risk of burning the immobilser wires out because they're quite thin.
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
