2003 Toyota Celica Wiring diagram
tello1
Posted: September 27, 2006 at 12:04 AM / IP Logged
I am in need of the stereo wiring diagram for a 2003 Toyota Celica. It has JBL speakers and is pre amplified from factory.
I'm hoping to install an after market stereo and have been unsuccessful finding a wire harness.
KarTuneMan
Platinum - Posts: 7,056
Posted: September 27, 2006 at 12:33 PM / IP Logged
+12V DC Battery(Constant)Blue / YELLOW  Radio 15 Amp Junction box behind panel, on right side of center console
Switched AccessoryGray  ECU-Acc 7.5 Amp Junction box behind panel, on right side of center console
Ground Brown
Power Antenna Black
Remote Turn On(output) Red
Illumination Green & WHITE/ green
Mute Brown
Left Front + White Line level output
Right Front + Red Line level output
Left Rear + Yellow Line level output
Right Rear + Blue Line level output
2003 Toyota Celica Wiring diagram -- posted image. AMPLIFIER OUTPUTS
Wire FunctionColorNoteFuse #SizeLocation
12V DC BatteryBlue / YELLOW  Radio 15 Amp Junction box behind panel, on right side of center console
Remote Turn On (input) Red Also gray for accessory switch, as for the radio unit above.
Left Front Tweeter + Pink To input 2 of tweeter, and out at 1 with pink/blue.
Left Front Tweeter - Violet To input 4 of tweeter, and out at 3 with violet/white.
Right Front Tweeter + Light green To input 2 of tweeter, and out at 1 with light GREEN/ red.
Right Front Tweeter - Blue To input 4 of tweeter, and out at 3 with blue/red.
Left Rear Mid + Black
Left Rear Mid - Yellow
Right Rear Mid + Red
Right Rear Mid - White
2003 Toyota Celica Wiring diagram -- posted image. AT SPEAKERS
Left Front Mid + Pink/blue
Left Front Mid - Violet/white
Right Front Mid + Lt.GREEN/ red
Right Front Mid - Blue/red
