passlock 1
extremelylow
Posted: October 04, 2006 at 11:08 PM / IP Logged
I got a 96 chevy impala. I cant seem to find this 3 wire riben or the wire with the risistence im i over looking something?
shaggy12volt
Copper - Posts: 164
Posted: October 04, 2006 at 11:17 PM / IP Logged
your car should be a VATS system read below
WIRING INFORMATION - CHEVROLET / IMPALA / 1996 / Remote Start
12volts red   +  ignition harness
Starter yellow   +  ignition harness
Second Starter
Ignition pink   +  ignition harness
Second Ignition
Third Ignition
Accessory orange   +  ignition harness
Second Accessory
Keysense
Power Lock lt. blue   +  drivers kick panel
Power Unlock white   +  drivers kick panel
Lock Motor gray    dirvers door harness
Unlock Motor tan    drivers door harness
Parking Lights+ brown or purple  +  headlight switch
Notes: Also found low in the drivers kick panel.
Parking Lights-
Hazards
Turn Signal(L)
Turn Signal(R)
Reverse Light
Door Trigger white   -  underdash light
Dome Supervision use door trigger
Trunk/Hatch Pin dk. green   -  low in drivers kick panel
Notes: Only available on some models.
Hood Pin
Trunk/Hatch Release BLACK/ white   +  at switch
Power Sliding Door
Factory Alarm Arm
Factory Alarm Disarm
Disarm No Unlock
Tachometer RED / black   AC 4 pin plug below intake
Notes: Remove the air cleaner assembly to access the connector. The connector is located a few inches from the center of the motor towards the passenger side. The motor will not start with the air cleaner assembly removed.
Wait to start
Brake Wire white   +  at brake pedal switch
Parking Brake
Horn Trigger black   -  steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
passlock 1 - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
VATS
Part #: 652T resistor pack
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: See DirectFax document 1049 for interface information.
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
dea,can
Copper - Posts: 284
Posted: October 06, 2006 at 3:15 AM / IP Logged
dragon
dea,can
Copper - Posts: 284
Posted: October 06, 2006 at 3:21 AM / IP Logged
passlock 1 - Last Post -- posted image.this is what u should have for your car.
dragon
extremelylow
Posted: October 06, 2006 at 12:13 PM / IP Logged
would you know why im get the check ingine light  only when i remote start . I got the pink. orange wired then i wired the brown no differance
Moderator - Posts: 12,488
Posted: October 06, 2006 at 9:38 PM / IP Logged
The check engine light will be on because the resistance is not quite within 95 % of the required value. How did you bypass the VATS ?
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
