Remote starter problems on a 1984 Caddy
natone98
Posted: October 08, 2006 at 6:40 AM / IP Logged
I have hooked up a Prestige Informer Model 996A to my 1984 Cadillac Coupe DeVille.  I have connected all the power wires as per diagram charts and double checking with test light.  I programmed the tach rate and have recieved confirmation from the brain that the programming has been sucsessful.
When I hit the button to start though the starter keeps spinning, the car keeps cranking, and does not stop until  I interupt.
Any ideas or help would be greaatly appreciated.
Thanks!
sparkie
Platinum - Posts: 2,061
Posted: October 08, 2006 at 11:49 AM / IP Logged
You aren't getting a good tach signal. Try reprogramming the tach source or find another one to use.
sparky
shaggy12volt
Copper - Posts: 164
Posted: October 08, 2006 at 12:54 PM / IP Logged
natone98I have connected all the power wires as per diagram charts and double checking with test light.
FIrst mistake useing a test light  You sould never use them things get a DMM
reprogram your tach
your tach wire is PURPLE / white  @ distributor/coil pack
Some coil packs rear of engine above transaxle.
The Shagmaster
1999 Chevy Suburban 15" lift sittn on 22's sets 7'5"
1992 Chevy Astro Van all Bagged out Dubbed THE SUICIDER
Installing for over 18 years Looking for empolyment NOW send PM for resum
natone98
Posted: October 08, 2006 at 10:44 PM / IP Logged
Ok, Ive tried reprogramming the tach 2 more times without any luck.  I will try another wire for the tach.  Most of the guides say white is the tach but Im also gettting advice about a purple / white wire so i will try this tommorow.  Thanks for the info guys, ill let you know what happened.
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
