Relay Drive on amp
Pi314
Posted: January 20, 2003 at 7:42 PM / IP Logged
I am running a 1989 Dodge Omni, and i have recently acquired a Sanyo amplifier and a speaker set. I want to install this system into my car, using the stock deck, until i get a newer one. I have ran into this problem, The amp, as it should, has a relay drive, or remote on wire, which i was going to hook up to my deck. However, the deck being so old, does not have such a connector. So my problem is that i would run it to some other power lead, however i did not know what voltage the remote on ran at. So, does anyone know what voltage the remote on connector runs at, and if so, can i just run it to the hot elad going to my radio if it is 12v?
Derrik
Member - Posts: 46
Posted: January 20, 2003 at 8:13 PM / IP Logged
i believe it's the same voltage (12 volt) very small current though..around 200mA
wvsquirrel
Gold - Posts: 1,237
Posted: January 20, 2003 at 11:02 PM / IP Logged
Most radios have a power antenna wire (regardless if the vehicle actually has a power antenna).  Hook up the remote lead to this wire, it's usually blue with a white stripe.  This will allow the amp to turn on when the HU comes on.  If it still doesn't come on, then the power antenna wire may only get juice if the radio (not CD or tape player) is on.  You could also hook it to the cigarette lighter wiring and add a toggle/rocker switch to manually turn the amp on and off.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
SnomanF150
Silver - Posts: 269
Posted: January 21, 2003 at 8:17 PM / IP Logged
Amp turn on is 12v.. you can use the ant up wire on most decks, but depending on the deck, I would use a relay to turn it on.. or, just hook it up to the 12v+ switched at the radio.. the amp will come on when you turn on the ign..
George
David's Car Stereo
Baton Rouge, LA
auex
Platinum - Posts: 5,041
Posted: January 21, 2003 at 8:50 PM / IP Logged
All you have to do is hook the remote lead to any acc wire.  It can either be at the radio or at the ignition harness.  All this wire has to do is go +12 volts when the key is in acc and in run.  You should also probably put a small fuse inline with this wire that way if the wire shorts out it won't blow the radio fuse or worse.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Sunday, May 12, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
