2006 Honda CR-V Alarm/Remote Start Wiring
Welcome Guest :)
brodybell
Member -
Posted: October 11, 2006 at 3:19 PM / IP Logged
Anyone have the diagrams for a starter/alarm combo?
KarTuneMan
Platinum -
Posted: October 11, 2006 at 7:12 PM / IP Logged
Remote start / security / GPS
Wire/Function | Colour | Location/Description | Polarity |
PASSIVE ANTI-THEFT | YES | TRANSPONDER | SEE NOTES |
12 VOLTS | White | In harness from Ignition switch | + |
IGNITION | BLACK / YELLOW | In harness from Ignition switch | + |
ACCESSORY | BLACK/ red | In harness from Ignition switch | + |
STARTER | BLACK/ white | In harness from Ignition switch | + |
KEY SENSE | RED / white | Ignition harness | - |
TACH SIGNAL | Blue/silver dots | At 1-pin plug next to battery | AC |
LOCK | WHITE/ blue | In gray connector above driver's kick | - |
UNLOCK | WHITE/ green | In gray connector above drivers kick | - |
DOORPIN | SEE NOTES | | |
| | GREEN is the driver's door, LT.GREEN/ RED is the passenger door, GREEN / WHITE is the rear doors. All 3 wires are found on the GREEN factory alarm connector on the left side of the steering column. See the photo. |
TRUNK PIN | SEE NOTES | | |
| | This wire is RED and is located on the GREEN factory alarm connector on the left side of the steering column. See the photo. |
TRUNK RELEASE | BLACK / YELLOW | In driver's kickpanel | - |
| | This wire only triggers when the hatch is closed. Close it each time you test it. |
BRAKESWITCH | WHITE/ black | At switch above brake pedal | + |
PARKLIGHTS | RED / black | In white connector above drivers kick | + |
| | You can also find BLUE (-) for lights at the GREEN Factory alarm plug on the left side of the steering column |
HAND BRAKE | GREEN/ orange | At switch in center console | - |
HORN | ORANGE / silver dots | At factory alarm connector | - |
| | Located on the GREEN factory alarm connector on the left side of the steering column. |
VSS WIRE | Blue/white | At cruise control module (left side of steering) | AC |
TRANSPONDER IGNITION | BLACK / YELLOW | At 7-pin plug on Ignition switch assembly | + |
TRANSPONDER DATA 1 | White | At 7-pin plug on Ignition switch assembly | DATA |
TRANSPONDER GROUND | BROWN / yellow | At 7-pin plug on Ignition switch assembly | - |
Available Notes
| PLEASE NOTE: This vehicle is equipped with an TRANSPONDER passive anti-theft system. Please refer to the appropriate diagram before any remote start installation. |
| N/A |
| N/A |
Moderator -
Posted: October 11, 2006 at 8:30 PM / IP Logged
Very easy vehicle to do. Not much has changed on the new CR-V's. Only thing I suggest is for you to get the keyless bypass modules for this Honda and not use a unversal type module.
crv2005
Member -
Posted: October 16, 2006 at 9:27 PM / IP Logged
I know that there is another accessory wire WHITE/ red, but not sure if that needs to be connected too? Does anybody know?
Thursday, May 9, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
