07 hyundai azera, alarm wiring
scootzpr5
Posted: October 12, 2006 at 6:13 PM / IP Logged
does anyone know where to get lock/unlock and factory arm/disarm? tia.
gcorrea
Silver - Posts: 436
Posted: October 12, 2006 at 7:51 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - HYUNDAI / AZERA / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      pink (40A), red (30A)       +       ignition harness
Starter      green       +       ignition harness
Second Starter      N/A
Ignition      blue       +       ignition harness
Second Ignition      N/A
Third Ignition      N/A
Accessory      orange       +       ignition harness
Second Accessory      orange       +       ignition harness
Keysense      GREEN/ black       -       ign harn or BCM, 16 pin plug, pin 8
Notes: The BCM (Body Control Module) is under the driver side dash, left of the brake pedal switch.
Power Lock      BROWN / orange       -       DDM, 23 pin plug, pin 16
Notes: Meter this wire while turning the key in the driver door key cylinder.
The DDM (Driver Door Module) is the power window main switch in the driver door.
Power Unlock      pink (double pulse)       -       DDM, 23 pin plug, pin 17
Lock Motor      red       5wi      dr kick or DDM, 16 pin plug, pin 9
Notes: The DDM (Driver Door Module) is the power window main switch in the driver door.
Unlock Motor      orange       5wi      DDM, 16 pin plug, pin 14
Parking Lights+      BROWN / org (L), gray/org (R)       +       back of fuse box, 20 pin plug
Parking Lights-      yellow       -       BCM, 26 pin plug, pin 8
Also found in the front of the fuse box, 20 pin plug, pin 5.
Hazards      WHITE/ orange       -       switch or BCM, 22 pin plug, pin 2
Turn Signal(L)      pink       +       dr kick or BCM, 14 pin plug, pin 14
Turn Signal(R)      orange       +       dr kick or BCM, 14 pin plug, pin 13
Reverse Light      white       +       back of fuse box, 9 pin plug, pin 5
Door Trigger      BLACK/ orange to black       -       dr kick or BCM, 22 pin plug, pin 1
Dome Supervision      yellow/orange to yellow       -       BCM, 14 pin plug, pin 2
Also found in the back of the fuse box, 24 pin plug, pin 7 or the driver side A pillar.
Trunk/Hatch Pin      green       -       dr kick or BCM, 22 pin plug, pin 12
Hood Pin      gray/orange       -       pin sw or BCM, 16 pin plug, pin 6
Trunk/Hatch Release      blue/orange       -       BCM, 26 pin plug, pin 21
Also found at the trunk release on/off switch in the glove box.
The trunk release motor wire is orange (+) in the back of the fuse box, 24 pin plug, pin 1.
The fuel lid release is green (+) in the driver kick, harness to the rear.
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      with ign, acc, and key sense
Tachometer      white to green       ac       PCM, connector A, pin 61
Notes: The PCM (Powertrain Control Module) is next to the driver side strut tower. Connector A is the plug towards the center of the vehicle.
Also found in the driver kick, 33 pin plug, pin 3 or the instrument cluster, 16 pin plug, pin 9.
Can also go to any fuel injector and use the wire that is NOT orange.
Can also go to any ignition coil and use the wire that is NOT pink.
Wait to start      N/A
Brake Wire      green to red       +       brake pedal switch or driver kick
Parking Brake      pink       -       switch or BCM, 22 pin plug, pin 13
Horn Trigger      white to yellow/orange       -       switch or BCM, 26 pin plug, pin 5
Memory Seat 1      WHITE/ orange       -       memory seat switch in door
Memory Seat 2      yellow/black       -       memory seat switch in door
Memory Seat 3      N/A       -
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
gcorrea
