2005 F150 Power Windows
gtchida
Copper - Posts: 89
Posted: October 23, 2006 at 12:59 AM / IP Logged
I checked the wiring diagrams for power window info but could not find anything - does anyone have wiring information for the '05 F150 4dr extended cab (it has moveable rear windows).
Thanks,
Gary
Twelvoltz
Platinum - Posts: 2,384
Posted: October 23, 2006 at 8:50 AM / IP Logged
DEI has this listed...I do not know if it only refers to the quad cab or if it will apply to the extended cab too. Should shed some light on it for you though.
DIRECTWIRE™ WIRING INFORMATION - FORD / F SERIES LIGHT DUTY / 2005 / Accessory
[PRINT THIS PAGE]
12voltslt. GREEN/ purple (20A) + ignition harness
Ignitiondk. blue/lt. green + ignition harness
Parking Lights+brown + switch or BCM, blue plug, pin 6
Notes: The BCM (Body Control Module) is on the driver side rear cabin wall.
Parking Lights-N/A
HeadlightRED / yellow + switch or BCM, blue plug, pin 9
Trunk/Hatch ReleaseN/A
Power Sliding DoorN/A
Speed Sensegray/black radio harness
Wipersblack to lt. blue/orange - windshield wiper switch
LF Window up/dntan/lt. blue - WHITE/ black A driver window switch in door
RF Window up/dntan/lt. blue - WHITE/ yellow A driver kick, door harness
LR Window up/dnyellow/lt. blue - gray/orange A driver kick, door harness
RR Window up/dnRED / black - yellow/black A driver kick, door harness
Notes: The rear power sliding window open is RED / yellow (5wi), and close is yellow/lt. blue (5wi). The wires are found at the switch in the roof or in the driver side C pillar. Use validity channels to control.
Sun Roof open/closemotor part of module
Sun Roof Limit/closeN/A
Memory Seat 1BROWN / lt. green - memory seat switch on seat
Memory Seat 2BLACK/ orange - memory seat switch on seat
Memory Seat 3N/A -
2005 F150 Power Windows - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
SecuriLock
Part #: 1100F
Alternate Part1 #: 556SW
Alternate Part2 #: 556UW
Alternate Part3 #: DesignTech 20402
Alternate Part4 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays:Relay Type:
Starter Relay
Underdash, Passenger side fusebox, #1
Part #: 6401A
Notes: Cycle key slow during programming or customer over ride
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
gtchida
Copper - Posts: 89
Posted: October 23, 2006 at 5:47 PM / IP Logged
Thanks for the info!
Gary
master5
Silver - Posts: 1,123
Posted: October 23, 2006 at 7:43 PM / IP Logged
Why didn't you just pop out the switch and look?
I know it saves time to have a diagram but if you are going to be cutting into higher current wires such as power window motors you really should verify every wire with a meter.
Wiring guides have mistakes all the time, systems change with no warning, and sometimes for no reason known to man, some or all wires are different then listed. Ford is notorious for this.
But regardless best of luck with it and post if you have any problems.
And please don't forget to use the fuse(s) or you may need a fire extinguisher.  ; )
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
