First Attempt at Glassing
jlaudiokyle
Posted: October 23, 2006 at 11:32 PM / IP Logged
Just a few pics of what I'm working on... Let me know what you think and any pointers/tips are greatly appreciated.
First Attempt at Glassing -- posted image.
glassmaster808
Member - Posts: 9
Posted: October 23, 2006 at 11:39 PM / IP Logged
That looks like it will come out pretty swell.....Good job. Keep the pic's comin.
auex
Platinum - Posts: 5,041
Posted: October 24, 2006 at 12:01 AM / IP Logged
Well since you are using 2 rings I would recommend flushing(sub mounts to the bottom ring and the top ring would rise to the top of the sub so it doesn't stick out) the sub in before you apply the resin. That is just me though.
I also would have left the bottom of the enclosure off to make sure that it gets a good seal around the pockets.
IMO you may have gone overboard with the staples.
Definately looks like good prep though. Do you have access to a router? It could help in the future with the edges and rings.
How are you planning on covering this enclosure? I hope either paint or suede flocking for the curves because carpet or vinyl would be a major pain.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
jlaudiokyle
Posted: October 24, 2006 at 12:11 AM / IP Logged
Yeah.. I had planned on routering the ring but it being installed into a standard cab ranger I had limited space. Especially between the seats. Right at 9" for a very tight fit. The sub is going to be a rockford fosgate P2 8" sub. The exterior of the mouting ring for the sub is 8 3/4" so I wouldn't have left me with much on each side. That's why it's going to be mounted directly to the top. As far as leaving the bottom off that sounds like something I'll consider for the future on another box. My ranger has kinda a uneven floor pattern I had to work with which turned out to be a 3/4" drop down so I made the box over shoot the drop about 3/4" and screwed the "point" piece to the bottom overlapping that 3/4" I added to the length of the box. And yeah it's going to be painted. I've worked with bondo and bondo-glass and have painted a good amount of times before.. i like that look better. but yeah it woulda been a pain haha. Thanks for the advice!
integratyper934
Copper - Posts: 150
Posted: October 24, 2006 at 1:29 AM / IP Logged
coming out good! i think your going to have a very fun time sanding thatFirst Attempt at Glassing -- posted image.
Aruman
Silver - Posts: 363
Posted: October 24, 2006 at 4:46 AM / IP Logged
lookings good, one thing i would do is resin inside the box for better sealing, but in your case you can't do it anymore. but it's a nice looking enclosure, good job.
Shaking The Neighborhood
jlaudiokyle
Posted: October 24, 2006 at 8:13 AM / IP Logged
yeah haha I'm sure it should be fun.. guess a little hard work pays off..
killer sonata
Silver - Posts: 718
Posted: October 24, 2006 at 1:46 PM / IP Logged
Looking good so far. Is it just me or in the 9th pic, does the sub ring not look centered? to me it looks like its more on the drivers side.
jlaudiokyle
Posted: October 24, 2006 at 3:50 PM / IP Logged
Yeah it was at the time.. I found out that my killer staple gun jarred the support loose from the back of the ring where it was glued and stapled. Thing's got a mind of it's own. Nothing new so far though. That's where I left off yesterday.. Today was project rabbit house. Had to build a rabbit house for my wife so it didn't freeze to death. So I recycled an old box of mine for 2 solo baric 15's. Monster box (13 cu.ft.) haha.
Melted Fabric
Silver - Posts: 509
Posted: October 25, 2006 at 3:02 PM / IP Logged
Nice job, it looks like it will be heavy, but sturdy nonetheless.
I have not failed. I've just found 10,000 ways that won't work.
When you do not know what you are doing and what you are doing is the best -- that is inspiration.
