’92 Explorer Factory Amplifier
cedman
Posted: October 25, 2006 at 12:40 AM / IP Logged
Does anyone know how to remove the factory amplifier from a 1992 Ford Explorer XLT? I just instalIed a Panasonic CQ-C5301U and I cannot get my speakers to work. If I install the amplifier by-pass I think this will solve my problem. I know where it is located but I do not know how to get to it. Can someone please help me?
forbidden
Platinum - Posts: 5,352
Posted: October 25, 2006 at 12:47 AM / IP Logged
Take out the entire right rear quarter panel of the vehicle to get to the amplifier.
KarTuneMan
Platinum - Posts: 7,056
Posted: October 25, 2006 at 12:59 AM / IP Logged
The inputs to the amp, and the outputs from the amp are in the pass. kick running down the entire rig all the way to the rear Qtr. Remove all the sill panals and expose the cable. Just where the cable goes under the rear seat, you can cut the entire cable. BE CAREFUL....there is also 12volts in that cable, so cut the wires one at a time. Identify the 12volt wire and put a butt connector on it. The outs from the amp are ford standard colors. You can the pull the cable end towards the front of the rig and run the cable to the opening in the dash. Hook the outs from the deck to the end of the cable ...amplifier is now bypassed, and you didn't have to tear down half the interior panals to do it.
opy1095
Member - Posts: 48
Posted: October 27, 2006 at 5:18 PM / IP Logged
why do u wanna bypass the factory amp?
tcss
Silver - Posts: 1,623
Posted: October 27, 2006 at 6:13 PM / IP Logged
You usually bypass the amp because the factory deck's output level is much lower then the aftermarket's and you get a real aggressive volume control.
There is no such thing as free installation!
aznboi3644
Gold - Posts: 2,600
Posted: October 28, 2006 at 8:01 PM / IP Logged
Yes i've experienced that with my 98 explorer...the speakers get loud at volume 10/35
Wednesday, May 15, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
