NSS how to?
snotdobbs
Copper - Posts: 148
Posted: November 01, 2006 at 1:38 PM / IP Logged
peripeheral electronics makes the NSS
acav1986
Member - Posts: 7
Posted: November 01, 2006 at 10:24 PM / IP Logged
Ok so if i am understanding correctly the PURPLE / white NSS wire should be hooked to the purple starter side wire from the 791 which yes does have the built in starter kill relay and provides a positive output. Then the purple wire of the NSS should be hooked to the starter wire on the starter wire and the 791 Key side green wire should be hooked to the key side of the starter wire?
Thanks again for all the help.
Alex
swamprat323
Gold - Posts: 1,335
Posted: November 01, 2006 at 10:51 PM / IP Logged
yes the PURPLE / white wire go to the starter side of the 791 realy pack and purple wire go to the green wire of the 791.
for any one that wants to see the manural on the NSS it is in the downlaod section under "peropheral neutral safety switch"
JWorm
Platinum - Posts: 2,208
Posted: November 01, 2006 at 11:56 PM / IP Logged
I still disagree. This method won't allow the car to start by key.
Do either the (-) purple starter wire in the ribbon cable between the brain and relay pack, or the BLACK/ white neutral safety input on the 791XV.
snotdobbs
Copper - Posts: 148
Posted: November 02, 2006 at 7:12 AM / IP Logged
wire in the purple and purple white to the negative start output from the remote start before the relay pack...........not the second negative start....the negative start thats part of the ribbon cable, and you should be fine.........It will always prevent the vehicle from remote starting if it hasnt seen the activation sequence.......and it will not interfere with the vipers starter kill or the ability to start it with the key......
uh yeah this is a repeat post
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
