Keep AB or Upgrade To D class?
brentyoung
Member - Posts: 9
Posted: November 04, 2006 at 7:46 PM / IP Logged
Hi, I have a Crossfire CFA602 and I plan on using a 15" Audiobahn AW151T rated at 600rms bridged@4ohms.  Should I keep this amp or invest in a Class D amp that's rated at the same watts? I'm just not sure if the AB would pull more current than the Class D because of the circuit design.   I may purchase a Power Acoustik A1800D rated at 600rms@4ohms.  Thanks for any info.
Knowledge is power. Never be afraid to ask questions.
aznboi3644
Gold - Posts: 2,600
Posted: November 04, 2006 at 11:26 PM / IP Logged
How is a sub rated to handle 600 watts at 4 ohms?? How much can it handle if its wired for 1 ohm?? 8 ohms??
I wouldn't invest in an Audiobahn amp??
master5
Silver - Posts: 1,123
Posted: November 04, 2006 at 11:49 PM / IP Logged
Why are you concerned about how much current the amp is "pulling"?
The only difference between the ab and d (aside from power depending on the models rating) is the class D amps are typically dedicated sub amps and mono, so you can actually connect a 2ohm (or 1 ohm again depending on the amps rating) load to it, with the 2 channel you can only connect a 4ohm load to it when bridging. All else being equal I doubt you would hear much difference between the 2.
As far as which will pull more current that depends on the efficiency of the specific amp, your ohms load, it's max output, and how much you crank the volume. Your main concern should be to not overpower the sub and blow it.
If you have flexibilty with your ohms load configuration you should be able to use a stereo or mono amp without issues.
advanced_audio
Copper - Posts: 170
Posted: November 05, 2006 at 12:10 AM / IP Logged
Are you planning on buying the Audiobahn or already have it? Seriously I would avoid Audiobahn at all costs.
stevdart
Platinum - Posts: 5,816
Posted: November 05, 2006 at 9:20 AM / IP Logged
If you are thinking about replacing amplifiers because of their potential demand on the system resources, you should do the appropriate math that will give you the answer you need:
Class A/B is approx. 60% efficient, with a factor of 40% as waste.
Class D is approx. 80% effiicient, with a waste factor of 20%.
Now, plug in your numbers.  You said 600 watts, so we'll use that as maximum RMS power.  If your amp is going to output 600 watts, it needs more than that much from the car's system resourcess because of the waste factor:
Finding the waste factor is a bit tricky for me as I am math-deficient.  We want to know what the draw on the system in watts has to be, in total, that will result in 600 watts after applying the waste factor.  I would first look at 600 watts / 1000 = 60% (apparent because 600 equates with 60%).  I'll have to use some trial-and-error to find the result for the class D amp, though, as 80% isn't as apparent as the 60% with these numbers.
A/B:  1000 * 60% efficiency = 600 watts.
D:  750 * 80% efficiency = 600 watts.
(Anyone who knows how to apply this math without resorting to trial-and-error, please post it.)
Looking at these numbers, now use Ohm's Law to find how that relates to amperage draw from the car's electrical resources.  Here's an Ohm's Law chart for reference.
Keep AB or Upgrade To D class? -- posted image.
To use Ohm's Law, if you have two known values you can find the third value.  You are considering power draw so you will use the system's resources as the known voltage.  With the engine running, voltage (E) can be considered to be 14.4 volts.  Power (P) is the demanded power we have found above.
I = P/E
I = 1000 watts / 14.4
I = 69 amps (current)
This is the determined draw for the class A/B amp.
I = P/ E
I = 750 watts / 14.4
I = 52 amps
This is the determined draw for the class D amp.
You see that at maximum draw, there is a difference of approx. 17 amps needed.
Let's also look at it in typical terms rather than maximum.  At 200 watts normal output rather than 600 watts, the difference in amperage draw (do the math as above) amounts to 7 amps.  You can look at the answer to this problem as being a difference ranging from 7 to 17 amps.
When you are contemplating major changes like this for the reason you stated, you are looking at saving 7 to 17 amps draw in total.  If your car's electrical system can't provide enough for the A/B amp and showing that in dimming lights, etc,, you need to upgrade the electrical system.  See "Big 3" and "h.o. alt".  The difference in power draw when changing to a class D amp is unlikely to fix the problem as that difference in current draw is relatively minor when you consider everything.
You also have to examine the quality of the gear you are thinking about replacing the amp with.  Are the specs known to be accurate with the given manufacturer?  What trade-offs will you incur?  But as you can see, using class D for subs is the smart way to go;  you just have to determine whether switching, for you, is the smart thing to do.
DYohn
Moderator - Posts: 10,741
Posted: November 05, 2006 at 10:02 AM / IP Logged
Steve's answer is what really matters in terms of changing amplifier class.  Thanks, Steve!
That being said, I would NEVER recommend replacing anything by Crossfire with anything from Power Acoustic.  That is a big downgrade in quality.  I would also not recommend purchasing Audiobahn.  There are far better subs out there in the same price range.
brentyoung
Member - Posts: 9
Posted: November 05, 2006 at 8:23 PM / IP Logged
The reason why I may choose to go with Power Acoustik because I was impressed by how much power it kicked out to two 12's I heard in a guys car at the barber shop.  I looked up the price because he was talking about how cheap the amp was and people are sleeping on it.  Plus I know a little about Class D amps.  I already have the Audiobahn AW151 T 15" and it's wattage RMS is 650 not 600rms.  What subs do you recommend and I plan on getting a seal enclosure build for the Audiobahn.  Is that a good choice?
brentyoung
Member - Posts: 9
Posted: November 05, 2006 at 8:26 PM / IP Logged
The sub is an single voice coil rated at 650rms 4ohms.   I will not be investing in a Audiobahn amp.
Thanks!
brentyoung
Member - Posts: 9
Posted: November 05, 2006 at 8:30 PM / IP Logged
I want to make sure my stock alternator will supply the amps it need.  If not enough i will purchase a high amperage alternator. Thanks for the information.
brentyoung
Member - Posts: 9
Posted: November 05, 2006 at 8:33 PM / IP Logged
I already have the Audiobahn speaker.  Tell me why you would choos another speaker?  Is it because the paper material the speaker cone is made of.  Thanks!
Page of 3
Thursday, May 16, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
