2000 Honda Accord, trunk release
cpugh
Member - Posts: 17
Posted: November 07, 2006 at 2:11 PM / IP Logged
I installed an aftermarket alarm on an 2000 Honda Accord.  everything works but the trunk release.  The wire from the alarm is (-)500mA but the honda wire is + at rest.  How do I hook this up?  Thanks
cp
bbtaco
Copper - Posts: 119
Posted: November 07, 2006 at 2:20 PM / IP Logged
It is a white /red wire in the drivers kick panel. You will need to use a relay.The correct wire in the car should show 12V when you press the Honda oem remotes trunk release.
Trunk release
Chris Luongo
Platinum - Posts: 3,746
Posted: November 07, 2006 at 4:35 PM / IP Logged
If you're at the driver's side fuse box, with your face positioned so that you can see the fuses......look down a little bit. There's a plug that's a little bit under the fusebox; the WHITE/ red is in there.
The instructions that came with your alarm should have wiring instructions for the relay.
