avistart 4001-97villager
Welcome Guest :)
albl
Member -
Posted: January 24, 2003 at 8:01 AM / IP Logged
i'm trying to install an avistart 4001 in a 97 merc villager with keyless entry the only wireing info i can find is for a non keyless entry car can any help me ?? I need wireing info for 97 merc villager with factory keyless entry.
thanks
albl
10nesne1
Silver -
Posted: January 24, 2003 at 9:26 AM / IP Logged
Remote Starter Wiring Colors and Notes |
Function | | | Vehicle Color | Location |
Start: | | | RED & WHITE/ BLUE | IGNITION SWITCH HARNESS *, ** |
Ignition #1: | | | BROWN | IGNITION SWITCH HARNESS |
Ignition #2: | | | RED / GREEN | IGNITION SWITCH HARNESS |
Ignition #3: | | | N/A | |
Accessory: | | | WHITE/ GREEN | IGNITION SWITCH HARNESS |
Brake Light: | | | YELLOW/BLACK (+) | AT SWITCH ABOVE BRAKE PEDAL |
Tach Signal: | | | GREEN | AT IGNITION MODULE ON TOP OF ENGINE |
Parking Lights: | | | PINK/BLUE OR PINK/WHITE (+) | DRIVER'S KICK PANEL |
Headlights: | | | RED / BLACK & GRAY/RED (+) | AT HEADLIGHT SWITCH *** |
OEM Alarm Disarm: | | | RED / BLACK (-) | DRIVER'S KICK PANEL OR SECU MODULE **** |
OEM Alarm Arm: | | | RED (-) | DRIVER'S KICK PANEL OR SECU MODULE **** |
Diesel Glow Plug: | | | | |
Clutch Bypass Wire: | | | | |
Notes: | | * Engine Control Module Located Behind Glove Box. ** This Vehicle Is Equipped With Two Start Wires. Both Must Be Powered In Order For Vehicle To Start When Engine Is Cold; See Note #251 - Nissan Starter Wires Diagram. |
Alarm and Keyless Entry Wiring Colors and Notes |
Constant +12 Volts: | | | WHITE/ PURPLE | IGNITION SWITCH HARNESS |
Starter Kill: | | | RED & WHITE/ BLUE | IGNITION SWITCH HARNESS *, ** |
Ignition +12 Volts: | | | BROWN | IGNITION SWITCH HARNESS |
Dome Lights/Superv: | | | RED / BLACK (-) | IN 2-PIN CONNECTOR IN CENTER CONSOLE |
OEM Horn: | | | BLACK (-) | STEERING COLUMN HARNESS |
Power Lock: | | | GREEN / WHITE (-) | DRIVER'S KICK PANEL ***** |
Power Unlock: | | | GREEN/ ORANGE (-) | DRIVER'S KICK PANEL ***** |
Trunk Release: | | | N/A | |
Alarm Input Wire: | | | RED / BLACK (-) | IN 2-PIN CONNECTOR IN CENTER CONSOLE |
Notes: | | |
Thursday, May 23, 2024
• Copyright © 1999-2024 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
