2005 Canyon alarm/auto-start
raiderj
Posted: November 08, 2006 at 5:53 PM / IP Logged
I just purchased a 2005 GMC Canyon and am looking to install an autostart (maybe an alarm/autostart). I'm finding lots of information on the internet, but I'm having a hard time getting it all straight in my head. A few questions:
What security bypass module are recommended? I've seen options from building one from relays to units by DEI and others.
If anyone has installed stuff on this vehicle, how would you recommend accessing the various wires? I know I'll need some 1A diodes to interface with the doors, but are there any other items I'd need?
Recommendations on alarm/autostart units? How about the Viper 791XV?
I'm not in a rush to do this, I'd like to really research everything first. I'm tired of taking my vehicles to people who do half-@ssed jobs. I have plenty of electronics experience and have decided to do things myself from now on!
Twelvoltz
Platinum - Posts: 2,384
Posted: November 08, 2006 at 7:22 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - GMC / CANYON / 2005 / Remote Start
[PRINT THIS PAGE]
12volts      WHITE/ black to orange (10A)       +       ignition harness
Starter      yel/blk (not for remote start)      -       PCM, blue plug, pin 48
Notes: The PCM (Powertrain Control Module) is on the passenger side firewall under the hood.
There is a WHITE/ blue (to white) wire and a WHITE/ yellow (to WHITE/ black) wire at the ignition harness, or the BCM, gray plug, pins A14 and A42, that performs the following: key sense, second ignition, starter, and Passlock resistance. Refer to DirectFax document 1603 for remote start interface information.
The BCM (Body Control Module) is in the passenger kick panel.
Second Starter      N/A
Ignition      WHITE/ green to dk. blue       +       ign harn or BCM, gray plug, pin B8
Notes: The BCM (Body Control Module) is in the passenger kick panel.
Second Ignition      see starter wire notes
Third Ignition      N/A
Accessory      WHITE/ red to brown       +       ign harn or BCM, gray plug, pin B7
Second Accessory      N/A
Keysense      see starter wire notes
Power Lock      lt. blue       -       either kick or BCM, blk plg, pin A11
Power Unlock      dk. blue       -       either kick, door harness
Notes: To unlock just the driver door use white (-) at the BCM, black plug, pin A12.
Lock Motor      gray       5wi      door lock switch in driver door
Unlock Motor      tan       5wi      door lock switch in driver door
Parking Lights+      brown       +       BCM, black plug, pin A48
Parking Lights-      BROWN / white       -       switch or BCM, gray plug, pin A7
Hazards      white       -       switch or BCM, gray plug, pin A48
Turn Signal(L)      lt. blue (F), yellow (R)       +       BCM, black plug, pins A3, B1
Turn Signal(R)      dk. blue (F), dk. green (R)       +       BCM, black plug, pins A19, B2
Reverse Light      lt. green       +       inside mirror or fuse box under hood
Door Trigger      see notes       -       BCM, black plug
Notes: The driver door trigger is gray/black in pin A32, the passenger door is lt. GREEN/ black in pin A38, the left rear door is lt. blue/black in pin A44, and the right rear door is BLACK/ white in pin A39. Use all four and diode isolate each.
Dome Supervision      white       -       BCM, black plug, pin A46
Trunk/Hatch Pin      N/A
Hood Pin      N/A
Trunk/Hatch Release      N/A
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      with ignition and Passlock
Tachometer      NOT pink or black       ac       any ignition coil or fuel injector
Wait to start      N/A
Brake Wire      lt. blue       +       brake pedal switch
Parking Brake      lt. blue       -       switch or BCM, black plug, pin A31
Horn Trigger      green to black       -       switch or BCM, gray plug, pin A25
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Passlock
Part #: N/A
Notes: See DirectFax document 1603 for wiring information.
Smart Starter Kill Relays:      Relay Type:
Starter Relay      Location:
Engine compartment fusebox, Driver side, #62
Part #: 6402A
Notes: Cycle key slow during programming or customer over ride
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
And use this for the bypass.
Moderator - Posts: 12,488
Posted: November 09, 2006 at 7:06 PM / IP Logged
raiderj wrote:
What security bypass module are recommended? !
I use the PLJX or PLXR from Bypasskit.com for this vehicle and it is very easy to install.
It's cheaper and easier to use the PLJX or PLXR IMO
raiderj wrote:
If anyone has installed stuff on this vehicle, how would you recommend accessing the various wires? !
Go to the BCM on the passengerside of the center console. Very easy to access and all your wires are there with the exception of some at the ignition switch.
raiderj wrote:
I know I'll need some 1A diodes to interface with the doors, but are there any other items I'd need? !
Use the wire information posted above.
raiderj wrote:
Recommendations on alarm/autostart units? !
Compustar 2WFM-AS-PRO or the 2W900FM-AS
raiderj wrote:
How about the Viper 791XV? !
Not a fan of the DEI stuff, but if your comfortable with the installation, go for it.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
