2005 Honda Accord Alarm/Remote Start Wiring
zenica
Copper - Posts: 116
Posted: November 09, 2006 at 9:45 PM / IP Logged
I was thinking of adding the 791XV to my wifes 05 Accord. Everyone here was so very helpful with my Z that I am once more turning to this board for help.
Anyone have an idea what wires and locations I'd need?
Thanks in advance...
cntrylvr79
Silver - Posts: 582
Posted: November 09, 2006 at 10:39 PM / IP Logged
12volts white (50A)  +  ignition harness
Starter BLACK/ white  +  ignition harness
Second Starter N/A
Ignition BLACK / YELLOW  +  ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory BLACK/ red  +  ignition harness
Second Accessory WHITE/ red  +  ignition harness
Keysense RED / white or RED / black  -  ign harn or MICU, green plug, pin 13
Notes: The MICU (Multiplex Integrated Control Unit) is part of the underdash fuse/relay box. The plug(s) for the MICU is on the left side edge of the fuse/relay box.
Power Lock pink/black  -  MICU, green plug, pin 25
Meter this wire while pressing the passenger door lock switch.
Power Unlock pink/blue  -  MICU, green plug, pin 9
Lock Motor yellow/black  5wi frt of fuse box, lt. grn 12 pin plug
Unlock Motor YELLOW /GREEN  5wi frt of fuse box, lt. grn 12 pin plug
Parking Lights+ RED / black  +  top of fuse box, large white plug
Parking Lights- RED / black  -  headlight switch in column cover
Hazards GREEN/ red  +  top of fuse box, large white plug
Turn Signal(L) RED / blue  +  top of fuse box, large white plug
Turn Signal(R) brown  +  top of fuse box, large white plug
Reverse Light green  +  driver kick, harness to rear
Door Trigger see notes  -  back of fuse box
Notes: The LF door is green in a lt. green 16 pin plug, pin 15. The RF door is lt. GREEN/ red in a lt. green 14 pin plug, pin 12. The LR door is GREEN/ YELLOW in a lt. green 16 pin plug, pin 14. The RR door is GREEN / WHITE in a lt. green 14 pin plug, pin 13. Use all four wires and diode isolate each.
Dome Supervision GREEN/ red  -  back of fuse box, lt. grn 5 pin plug
Trunk/Hatch Pin blue/black  -  MICU, green plug, pin 24
Hood Pin yellow/red to GREEN/ black  -  hood pin switch in latch
Trunk/Hatch Release YELLOW /GREEN  +  driver kick, harness to rear
Power Sliding Door N/A
Factory Alarm Arm blue/white to WHITE/ red  -  driver door module in door
Factory Alarm Disarm BLACK/ red to white  -  driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer blue/red or blue  ac  ECM/PCM
Notes: The ECM/PCM is on the front of the transmission tunnel. The connectors are on the passenger side. On the 4 cylinder models the tach wire is in the white 31 pin connector E, pin 25. On the 6 cylinder models it is in the gray connector A, pin 23.
Can also go to any ignition coil and use the wire that is NOT BLACK/ white or black.
Can also go to any fuel injector and use the wire that is NOT yellow/black.
Wait to start N/A
Brake Wire WHITE/ black  +  brake pedal switch
Parking Brake GREEN/ orange  -  top of fuse box, large white plug
Horn Trigger GREEN/ YELLOW  -  horn switch
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
2005 Honda Accord Alarm/Remote Start Wiring - Last Post -- posted image.
Interface Module:Category:
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556HW
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on all models. When using the 556HW, follow the mode 1 wiring diagram. The reference wire is BROWN / yellow, data wire is RED / blue and ignition wire is BLACK / YELLOW.
Cause I'm So white and nerdy...
First Class Certi-fried installer
cntrylvr79
Silver - Posts: 582
Posted: November 09, 2006 at 10:40 PM / IP Logged
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Wait to start N/A
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Immobilizer Bypass
Required:
Yes
Type:
Transponder
Part #: 556HW
zenica
Copper - Posts: 116
Posted: November 10, 2006 at 5:08 PM / IP Logged
Nice!
Thanks!
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
