Prostart Ct-5000 in 1996 Honda Civic
faisalymalik
Posted: November 10, 2006 at 12:50 AM / IP Logged
All help appreciated!!
Hello! I am trying to install a Prostart CT-5000 into my 1996 Honda Civic EX Sedan (manual). I only want to install the security and keyless features (not the remote start). I have trouble with the wiring. I wanted to confirm my findings, and I am looking for advice/input. If anyone can tell me which wire get connected with what, that would be much appreciated. Attached are the details of the wiring, first for the unit and then for the car. My first post, I apologize for any mistakes in my post.
Prostart CT-5000 Wiring Info:
Please visit the website below: I tried pasting it here but its Adobe Reader:
http://www.engines911.com/asdocs/CT-5060_ig_en_h370s380v355_040909.pdf
Here's the wiring info for my Honda Civic 1996 EX:
FUNCTION     DATACOLOR     LOCATION     POLARITY
+12 VOLTS     WHITE     IGNITION HARNESS     +
IGNITION     BLACK / YELLOW     IGNITION HARNESS     +
IGNITION 2     N/A     NOT AVAILABLE     N/A
ACCESSORY     YELLOW     IGNITION HARNESS     +
ACCESSORY 2     N/A     NOT AVAILABLE     N/A
STARTER     BLACK/ WHITE     IGNITION HARNESS     +
STARTER 2     N/A     NOT AVAILABLE     N/A
TACHOMETER     BLUE     TACH TEST CONNECTOR     AC
INJECTOR     N/A     NOT AVAILABLE     N/A
PARKING LIGHTS     RED / BLACK     DRIVER'S KICK PANEL     +
BRAKESWITCH     GREEN / WHITE     BRAKE SWITCH     +
CLUTCH BYPASS     N/A     NOT AVAILABLE     N/A
PARKING BRAKE     RED / GREEN     DRIVER'S KICK PANEL     -
HOODPIN     N/A     NOT AVAILABLE     N/A
GLOW PLUG     N/A     NOT AVAILABLE     N/A
LOCK     GREEN / WHITE     DRIVER'S KICK PANEL     -
UNLOCK     GREEN/ ORANGE     DRIVER'S KICK PANEL     -
TRUNK RELEASE     ADD SOLENOID     NOT AVAILABLE     N/A
ARM     N/A     NOT AVAILABLE     N/A
DISARM     N/A     NOT AVAILABLE     N/A
DOORPIN     BLACK/ WHITE OR GREEN/ RED     DRIVER'S KICK PANEL     -
TRUNK PIN     N/A     NOT AVAILABLE     N/A
Security:
Comments: FACTORY ALARM CONNECTOR IS A GREEN PLUG BEHIND RADIO.
Thankyou for your help!
fas
gcorrea
Silver - Posts: 436
Posted: November 11, 2006 at 5:31 PM / IP Logged
best bet would be to take it to a shop and get it installed. if you have no idea what all those wires do read up on it and study exactly what each wire does and its fuction. you got to start by learning your basic 12volts.
gcorrea
KarTuneMan
Platinum - Posts: 7,056
Posted: November 19, 2006 at 8:27 PM / IP Logged
This car is pretty straight foward.....but as gcorrea stated, you need some basic education before starting something like this. It would be a REAL shame to burn your own car to the ground, because of your lack of knowledge.
Saturday, April 27, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
