2006 Monte Carlo
deeddude
Posted: November 19, 2006 at 3:50 AM / IP Logged
Need wiring info for this vehicle. It has keyless entry and remote start, I would like to install an aftermarket alarm and interface it with the factory remote start. Any help is appreciated. Thanks.
gcorrea
Silver - Posts: 436
Posted: November 19, 2006 at 9:14 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - CHEVROLET / MONTE CARLO / 2006 / Remote Start
[PRINT THIS PAGE]
12volts      RED / white (10A)       +       ign harn or BCM, blue plug, pin 3
Notes: The BCM (Body Control Module) is to the left of the steering column.
Starter      yellow (not for remote start)       +       ECM
Notes: On the V6 models, the starter wire is in the blue plug, pin 26.
On the V8 models, the starter wire is in the black plug, pin 22.
The ECM (Engine Control Module) is behind the driver side headlight, in the air cleaner assembly.
There is a white wire and a WHITE/ black wire in the ignition harness, or the BCM, green plug, pins 2 and 4, that perform starter, second ignition, and key sense functions. No information at this time, if it is necessary to interface with these wires in addition to the PASS-key III+.
Second Starter      N/A
Ignition      pink       +       ign harn or BCM, green plug, pin 14
Second Ignition      see starter wire notes
Third Ignition      N/A
Accessory      brown       +       ign harn or BCM, green plug, pin 21
Second Accessory      N/A
Keysense      see starter wire notes
Power Lock      ORANGE / black       -       driver kick or BCM, gry plug, pin 12
Power Unlock      ORANGE / black       -       driver kick or BCM, gry plug, pin 11
Lock Motor      gray       5wi      DKP or fuse box, 40 pin plug, pin J2
Notes: The fuse box is on the passenger side, end of the dash.
Unlock Motor      tan       5wi      DKP or fuse box, 40 pin plug, pin J3
Parking Lights+      purple (L), BROWN / white (R)       +       passenger kick, harness to rear
Parking Lights-      BROWN / white       -       switch or BCM, white plug, pin 8
Hazards      tan       -       switch or BCM, green plug, pin 19
Turn Signal(L)      lt. blue/white (F), yellow (R)      +       BCM, brn plg, pin 4; brn plg, pin 1
Turn Signal(R)      dk. blu/wht (F), dk. green (R)      +       BCM, blk plg, pin 5; brn plg, pin 2
Reverse Light      lt. green       +       pass kick or BCM, pink plug, pin 2
Door Trigger      gray/black (D), tan/white (P)       -       ea kick or BCM, pnk plug, pins 10, 8
Notes: Use both wires and diode isolate each.
Dome Supervision      gray/black       +       driver kick or BCM, pink plug, pin 1
Trunk/Hatch Pin      ORANGE / black       -       pin switch or BCM, pink plug, pin 12
Hood Pin      pink/black       -       pin switch or BCM, blk plug, pin 17
Trunk/Hatch Release      lt. blue       -       switch or BCM, white plug, pin 10
The trunk release motor wire is tan/white (+) at the fuse box, 40 pin plug, pin A5. The fuse box is on the passenger side, end of the dash.
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      with ignition and Passkey
Tachometer      NOT pink/black       ac       any fuel injector
Wait to start      N/A
Brake Wire      lt. blue       +       kick panel or BCM, brown plug, pin 5
Parking Brake      ORANGE / black       -       switch or BCM, pink plug, pin 22
Horn Trigger      tan       -       switch or BCM, brown plug, pin 18
Memory Seat 1      N/A
Memory Seat 2      N/A
Memory Seat 3      N/A
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
PASS-Key III+
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes: Standard on all models.
Smart Starter Kill Relays:      Relay Type:
Starter Relay      Location:
Engine compartment fusebox, Passenger side
Part #: 6402A
Notes: If equipped with factory remote start, SSKR not recommended
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
gcorrea
deeddude
Posted: November 22, 2006 at 8:13 PM / IP Logged
Thanks for the reply, sorry for the delay. I don't get out much.
snotdobbs
Copper - Posts: 148
Posted: November 23, 2006 at 10:45 AM / IP Logged
yeah i dont know how you would interface it with the factory remote start.......astrostart puts out a factory remote start range extension control module but i dont think it works with every gm vehicle.....you may be better off just installing a remote start/alarm combo unit....but i dont think that there is any kind of remote start activation input for your factory starter that uses an analogue signal.
deeddude
Posted: November 24, 2006 at 4:59 AM / IP Logged
Thanks, that's what I was afraid of (no interface). The range for the remote is terrible.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
