04 Saab 9.3 Alarm/Remote Start Wiring
audiopete
Copper - Posts: 82
Posted: November 19, 2006 at 7:48 PM / IP Logged
any one have this info thanks doing  remote start and keyless
gcorrea
Silver - Posts: 436
Posted: November 19, 2006 at 9:13 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - SAAB / 9-3 / 2004 / Remote Start
[PRINT THIS PAGE]
12volts      RED / white       +       ignition harness
Starter      brn/wht (NOT for remote start)      -       ECM, driver side connector, pin 58
Notes: The ECM is on the front passenger side of the engine.
Second Starter
Ignition      RED / blue       +       ignition harness
Second Ignition
Third Ignition
Accessory      blue       +       ignition harness
Second Accessory
Keysense      brown       +       ignition harness
Power Lock      green (4D), yellow (CV)       -       central lock switch in driver door
Notes: Lock and unlock are negative trigger thru resistors. The resistor values are not know at this time. Cut the wire and meter the switch side while pressing the central lock switch on the door.
Power Unlock      same wire as power lock
Lock Motor      black or blue/red       5wi      driver door module in door
Unlock Motor      black or RED / blue       5wi      driver door module in door
Parking Lights+      use parking lights (-) wire
Notes: Each light is controlled separately by the underhood and rear electrical centers.
Parking Lights-      BROWN / yellow       -       headlight switch or BCM, pin A29
Notes: The BCM is part of the fuse box under the driver side dash.
Hazards      BROWN / white       -       hazard switch or BCM, pin B61
Turn Signal(L)      use hazards wire
Turn Signal(R)      use hazards wire
Reverse Light      black, red, blue, or brown       +       reverse light in trunk
Door Trigger      see notes       -       each door harness or BCM
Notes: The LF door is green to gray in pin A12. The RF door is green to ORANGE / blue in pin A11. The LR door is purple to BROWN / orange in pin A10. The RR door is purple to white in pin A9. Use all four wires and diode isolate each.
Dome Supervision      blue/white       -       driver kick or BCM, pin A18
Trunk/Hatch Pin      purple       -       driver kick or BCM, pin A32
Hood Pin      yellow/blue to GREEN/ gray       -       pin switch or BCM, pin B60
Trunk/Hatch Release      GREEN / WHITE to BROWN / red       -       driver kick or BCM, pin B58
Meter this wire while opening the trunk with the rear trunk lid handle.
Power Sliding Door      N/A
Factory Alarm Arm      factory remote only
Factory Alarm Disarm      factory remote only
Disarm No Unlock      with ignition and transponder
Tachometer      NOT red, RED / yellow, or black       ac       any ignition coil or fuel injector
Wait to start      N/A
Brake Wire      RED / green       +       brake pedal switch
Parking Brake      ORANGE / blue to ORANGE / white       -       parking brake switch or BCM, pin B55
Horn Trigger      blue/white       -       Column Integration Module
Notes: The Column Integration Module is in the steering column.
The horn trigger is also brown (+) at the horn behind the front grille.
Memory Seat 1      WHITE/ red (4D), RED / gray (CV)       +       memory switch on driver seat
Memory Seat 2      PURPLE / wht (4D), gray/wht (CV)      +       memory switch on driver seat
Memory Seat 3      GREEN/ pur (4D), gray/blue (CV)      +       memory switch on driver seat
Interface Module:      Category:
Immobilizer Bypass      Required:
Yes      Type:
Transponder
Part #: 556UW
Alternate Part1 #: DesignTech 20402
Alternate Part2 #: DesignTech 29402
Notes:
Smart Starter Kill Relays: Not Available
warning
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this
gcorrea
Fastlearner
Silver - Posts: 346
Posted: November 19, 2006 at 9:59 PM / IP Logged
Just be prepared, I'm not sure what kind of saab I did earlier in the year but I couldn't get it to work, so good luck
audiopete
Copper - Posts: 82
Posted: November 20, 2006 at 6:29 PM / IP Logged
thanks guys for the info but what about the starter wire they say not to use it .thanks
