2006 Toyota Tundra DC V8 Alarm/Remote Start Wiring
jpease
Member - Posts: 9
Posted: November 20, 2006 at 9:26 AM / IP Logged
Looking for wiring information for Toyota Tundra 2006 X-SP Double Cab (Full 4 Doors)
V8, automatic, power windows, power locks, no OEM alarm,
KarTuneMan
Platinum - Posts: 7,056
Posted: November 20, 2006 at 10:13 AM / IP Logged
 MODEL YEAR(S)
 TUNDRA DOUBLE CAB  2004 -2006
 KEY T-HARNESS IMMOBILIZER
  N/A   TOY-1   N/A
 PART  COLOR LOCATION
 12 VOLT CONSTANT  WHITE/ RED (+) and WHITE/ BLUE (+)   IGNITION SWITCH HARNESS
 STARTER BLACK/ WHITE (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 BLACK/ RED (+) IGNITION SWITCH HARNESS
 IGNITION 2 BLACK / YELLOW (+) IGNITION SWITCH HARNESS
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 PINK (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE YELLOW /GREEN (-)  IGNITION SWITCH HARNESS
 PARKING LIGHTS ( - ) GREEN (-)  @ HEADLIGHT SWITCH or BCEU, WHITE Plug, PIN 14, See NOTE *2
 PARKING LIGHTS ( + ) GREEN (+)  IN DRIVERS KICK PANEL, HARNESS to REAR of VEHICLE
 POWER LOCK See NOTE *1  See DIAGRAM
 POWER UNLOCK See NOTE *1  See DIAGRAM
 DOOR TRIGGER See NOTE *3  @ BECU, See NOTE *2
 DOMELIGHT SUPERVISION BLUE/BLACK (-), Requires Part #775 Relay  @ IGNITION KEY CYLINDER ILLUMINATION
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN BLACK / YELLOW (-)  @ BECU, BLACK Plug pin 21, See NOTE *2
 TACH WHITE/ BLUE (-)  @ ECM, RIGHT Plug, Pin 5, See NOTE *4
 WAIT TO START LIGHT N/A
 BRAKE GREEN / WHITE (+) or WHITE/ RED (+)  @ SWITCH ABOVE BRAKE PEDAL
 FACTORY ALARM DISARM  DISARMS with KEYSENSE wire, See NOTE *5  @ IGNITION SWITCH HARNESS
 ANTI-THEFT N/A
 EXTRA INFORMATION
 NOTE *1 this vehicle will requires extra parts when connecting for the KEYLESS ENTRY System, an extra Relay part #775 and diodes, to connect, See DIAGRAM NOTE *2 the BECU (Body Electronic Control Unit) is located above the DRIVERS KICK PANEL, next to the FIREWALL. NOTE *3 the DRIVERS DOOR is a GRAY/RED (-), GRAY Plug, Pin 15, the PASSENGER DOOR is a LIGHT GREEN/ BLACK (-) BLACK plug pin 8, the DRIVERS REAR DOOR is a RED / WHITE (-) GRAY plug, pin 16, the PASSENGER REAR DOOR is a RED / WHITE (-) BLACK plug pin 4. When connecting to an ALARM SYSTEM, use all (4) DOOR TRIGGER wires and DIODE ISOLATE, to connect, See DIAGRAM. NOTE *4 the ECM (Engine Control Module) is located behind the GLOVE BOX. NOTE *5 THE KEYSENSE WIRE WILL DISARM THE VEHICLE WITHOUT UNLOCKING THE DOORS BY APPLYING A (-)NEGATIVE TO THIS WIRE DURING REMOTE STARTING.
jpease
Member - Posts: 9
Posted: November 20, 2006 at 12:34 PM / IP Logged
Thanks for your help, in ref Note #1 diagram is there a link to the diagram?
thepencil
Gold - Posts: 1,526
Posted: November 20, 2006 at 3:29 PM / IP Logged
DIRECTWIRE™ WIRING INFORMATION - TOYOTA / TUNDRA DOUBLE CAB / 2006 / Remote Start
12volts wht/blue (40A), wht/red (25A)   +   ignition harness
Starter BLACK/ white   +   ignition harness
Second Starter N/A
Ignition BLACK/ red   +   ignition harness
Second Ignition BLACK / YELLOW   +   ignition harness
Third Ignition N/A
Accessory pink   +   ignition harness
Second Accessory N/A
Keysense YELLOW /GREEN   -   ign harn or BECU, black plug, pin 22
Notes: Using the status output wire from the remote start to trigger this wire will disarm the alarm without unlocking the doors.
The BECU (Body ECU) is above the driver kick panel, towards the firewall.
Power Lock see DirectFax document 1070
Power Unlock see power lock
Lock Motor blue/red   5wi DKP or BECU, black plug, pin 1
Notes: The BECU (Body ECU) is above the driver kick panel, towards the firewall.
Unlock Motor RED / black   5wi DKP or BECU, black plug, pin 14
Parking Lights+ green   +   driver kick, harness to rear
Parking Lights- green   -   switch or BECU, white plug, pin 14
Hazards GREEN/ red   -   turn signal flasher below fuse box
Turn Signal(L) GREEN/ black   +   turn signal flasher below fuse box
Turn Signal(R) GREEN/ YELLOW   +   turn signal flasher below fuse box
Reverse Light RED / black   +   driver kick, gray 8 pin plug, pin 2
Door Trigger blue/red (ajar indicator)   -   BECU, white plug, pin 1
The individual door trigger wires are also at the BECU. The LF door is gray/red, gray plug, pin 15. The RF door is lt. GREEN/ black, black plug, pin 8. The LR door is RED / white, gray plug, pin 16. The RR door is RED / white, black plug, pin 4. Use all four wires and diode isolate each.
Dome Supervision blue/black   -   ignition key cylinder illumination
Notes: Also found at the BECU, gray plug, pin 8.
Trunk/Hatch Pin N/A
Hood Pin blue/white   -   pin sw. or BECU, white plug, pin 5
Trunk/Hatch Release N/A
Power Sliding Door N/A
Factory Alarm Arm arms with lock
Factory Alarm Disarm disarms with unlock
Disarm No Unlock use key sense wire
Tachometer black   ac   ECM, 2nd plug from right, pin 1
Notes: The ECM (Engine Control Module) is behind the glove box.
Wait to start N/A
Brake Wire WHITE/ red or GREEN / WHITE   +   brake pedal switch
Parking Brake lt. GREEN/ red   -   switch or BECU, black plug, pin 3
Horn Trigger BLACK / YELLOW   -   switch or BECU, black plug, pin 21
Memory Seat 1 N/A
Memory Seat 2 N/A
Memory Seat 3 N/A
Interface Module: Category:
Immobilizer Bypass Required:
No Type:
N/A
Part #: N/A
Notes:
Door Lock Interface Required:
No Type:
Data Bus
Part #: IM-Toyota-2
Notes:
Smart Starter Kill Relays: Not Available
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
37Z_1070.pdf
Be careful whose advice you buy, but be patient with those who supply it.2006 Toyota Tundra DC V8 Alarm/Remote Start Wiring - Last Post -- posted image.
jpease
Member - Posts: 9
Posted: November 20, 2006 at 8:01 PM / IP Logged
most appreciated guys!!!!  over the next day or so I will putting down what I want to do with the alarm and how I intend to do it.  Of course, I am looking to read everyones comments.
Mike M2
Platinum - Posts: 2,652
Posted: November 21, 2006 at 6:27 AM / IP Logged
Easy truck, not many shortcuts to take. Use the supervision wire for door trigger, it catches all 4 doors. I use a coil wire instead of going to the BCM, lots easier. When wiring the 1070 document, use the WHITE/ black at the door switch for ground(the metal of the door tends to not make a solid ground going thru the hinges). No immobilizer....
Mike M2
Tech Manager
CS Dealer Services
jpease
Member - Posts: 9
Posted: November 21, 2006 at 3:37 PM / IP Logged
I have a new Autopage LCD 860 Alarm and here is what I am looking to do:
Remote start
Starter kill switch
Remote windows up and down
Remote door locks
Mercury switc
Battery back up
Extra piezo sirens inside the cabin
Remote placement of the controller/cpu
A little background, I have done a couple of alarms in my days, car and residential audio.  Comments?
Saturday, May 4, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
