2000 Ford Contour, alarm
hugosalinas
Posted: November 21, 2006 at 9:06 AM / IP Logged
Im begginer, yesterday i canīt connect my first alarma Xpress.
1.-What  means pager set, and where conect this wire.
2.-i need Choose the 4 wires of my car to conect just one 1 wire to roll up, in the alarm.(Window roll up).
car ford contour 2000, 4 doors,
topper
Copper - Posts: 56
Posted: November 21, 2006 at 11:57 PM / IP Logged
  take your car and alarm to your local alarm shop and pay $100-$150 to have them install your alarm. This will be much cheaper then then damage you will inflict on you vehicle.
mjwood0
Member - Posts: 38
Posted: November 22, 2006 at 8:07 AM / IP Logged
I have a Contour as well. They aren't too bad from what I've seen, but they aren't without their quirks. Plus there is very little to solder in if you are new to this (as with most cars).
If you can't figure out the wiring you may be better off going to an install shop. You would really hate to fry anything under the dash. Very expensive to replace harnesses when they burn (not to mention if the car burns).
hugosalinas
Posted: November 22, 2006 at 9:40 AM / IP Logged
partners just i want to know , what means the wire NEGATIVE PULSED OUTPUT FOR PAGER CALL.
WHERE CONECT THIS WIRE OR  DOSNīT CONECT THIS WIRE.
ALARM  XPRESS. MODEL DX360.
FORD CONTOUR 20002000 Ford Contour, alarm -- posted image.
hugosalinas
Posted: November 23, 2006 at 9:06 AM / IP Logged
Today Im going to install my alarm Xpres, can conect both wires, alarmīs siren and vehicleīs horn,
Contour 2000 .
Tuesday, May 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
